Results 1 to 20 of 23
Thread: Remote Starter Problems
    Mar 2006
    Time Online: 3 Days 15 Hrs 24 Mins 27 Secs
    Avg. Time Online: 18 Secs
    I just bought a 2003 Chevy Montana with a remote start installed. I'm not sure what make it is but by the remote it looks like a cheaper Crappy Tire brand. When I push the "start" button it flashes the lights and looks like it is going to start (no turnover or sounds) and then flashed the parking lights 3 times...no dice. From inside the vehicle I put the key in the "on" position and pressed the "start" button and it fired it up?? Does it sound like a loose connection or a bad module?
    Thx, Jay
    Sounds like a shit aftermarket remote start that will cause no end to the headaches down the road. As i advise to all my clients. REMOVE IT.
    Kitchener - Waterloo
    Time Online: 1 Day 1 Hr 37 Mins 27 Secs
    Three blinks could be hood pin depending on model. If it was the bypass the remote start would trip the factory alarm and you'd have to wait ten mins to start it. Check for a hood pin under your hood, and see if the light on the dash ( led) or it might be on the ant, see if its flashing all the time.
    OF4WD# 5253
    1989 Islander YJ SOLD
    1997 TJ Sahara 35s, Warn 8000, Jet Chip, Flexilite Fan, 6 inchs of lift. blahSOLD!
    1999 Ford F-150 4X4
    02 Polaris Sportsman 700
    RDC lift, RDC Relocate , blah, blah, and blah.
    LugNutz's Avatar
    Avg. Time Online: 4 Mins 9 Secs
    I don't think the hood pin is the problem (Although 8 times out of 10 it is), if it was the pin, the RS wouldn't work with the key in. I'm thinking maybe vehicle immobilizer not getting a signal. A quick way to tell is put the key in the ignition cylinder, but don't turn it on, then try using the remote start. If it starts, it's the immobilizer interface.
    Mar 2006
    I agree it is a shit aftermarket...it does not start if I just put the key in the ignition, it must be in the "on" position. I will check the hood pin and if that's not it, it's probably not worth the time to troubleshoot it.
    Thx again, I'll let you know how it goes.
    LugNutz's Avatar
    Some units also had fuses on the power, ignition feeds, but I doubt that would give you such symptoms. Can you find out the brand and maybe I can get the diagnostic codes for you.
    Mar 2006
    I haven't had a chance to check for the actual module in the van, but the remote has "Premier" on it.
    everglades of lower suburbia
    Time Online: 26 Mins 34 Secs
    mine does that when it pops one of the ign fuses
    Mar 2006
    the ign fuse in the unit itself or in the car? does it start at all? I'll check the fuses tomorrow.
    Time Online: 3 Wks 5 Days 2 Hrs 47 Mins 8 Secs
    Avg. Time Online: 2 Mins 9 Secs
    i have a problem with my auto starter as well. Since i replaced my engine in my 97 TJ the remote turns the engine over 3 times automatically but it never catches and doesnt start. With the key it starts no problem? WTF?
    I have Anal Glaucoma- I can't see my ass coming into work today.
    the fuse for the unit itself
    Apr 2004
    Milton, ON
    Time Online: 22 Hrs 35 Mins 59 Secs
    Try dropping the key on the front seat and pressing the start button, I have heard that many GM keys have a chip in them with a proximity sensor to know the key is in.
    I had inquired about putting a remote start in my Venture and I was asked if I had an extra key that they could tie up under the dash so that it could start.
    Just what I heard.
    Mike - 08 JK, 4 dr, Silver.
    Quote Originally Posted by Blubberpud View Post
    Thx, Jay
    Sorry But is it a CHEV VENTURE or PONTIAC MONTANA. There is no such thing as a chev montana
    Quote Originally Posted by mbfrosch View Post
    Just what I heard.
    Yes the '03s use a chipped key. They are called pass key 3
    Mar 2006
    Quote Originally Posted by C.C. View Post
    LOL yea shows how much I drive it....it is a PONTIAC MONTANA thks.
    And thanks for all the suggestions but still haven't got it to work..oh well all the cold weather is hopefully gone now anyway
    '05 TJ, mall crawler
    '96 ZJ Limited, 5.2L
    '92 YJ, 4 Banger, 3.5" Lift on 33"s, Locked, Posi-Lok, Cobra CB --GONE :`(.
    "I'd try to see things from your point of view, but I can't fit my head that far up my ass."
    "When life gives you retards....hold a telethon"
    Nov 2003
    Welland
    Time Online: 1 Wk 3 Days 10 Hrs 33 Mins 37 Secs
    Avg. Time Online: 51 Secs
    I had a problem with mine that I had put in my Dodge Dakota. The Girlfriend bought me one for Christmas from Best Buy and I had it installed in my Dakota. It worked when I picked it up, and never worked after that. I went back a few weeks later, and they explained to me I had to "Set it" everytime I got out (its a standard truck) and that every time I get out, I have to have the e-brake on, the shifter in Neutral, and hit the starter button with the truck running. The dash lights flash and come on, and when I turn the key off and take it out, it stays running. I get out and shut the door, then have to hit the door lock button with the doors shut and the motor then turns off. Next time I go to get in, the remote start will work, unless I open my door before I try to start it.
    1987 Jeep YJ - Daily driver/trail rig - On the road but Currently under construction
    Thanks everyone for helping me realise I really do dislike people in general
    I'm just a regular Joe, with a regular Job, I'm your average white Suburbanite slob
    I like Football, and Porno, and Books about War
    Thx, Jay
    If the van will start with the key in the run position, it's likely the Passlock3 module bypass has failed. The remote starter also should not allow a remote-start cycle to occur with the key in the run position, you you're likely looking at a shoddy installation.
    Quote Originally Posted by BEATSTTC View Post
    Either your anti-theft is not disabled during remote start cycle (most likely) or the fuel pump/ignition/ASD is not getting powered up during remote start cycle. If it's never worked, I would expect someone messed up on the 2 wires that need power during the remote-start cycle and forgot one.
    Quote Originally Posted by apuszczalowski View Post
    That's normal & installed correctly. It's a safety precaution. Consider yourself lucky - most shops will not install remote starters for fear of liability. You could, in theory, shut it down properly then reach through the open window and slam it in gear. If you remote start the truck, it will run away.
    I've installed dozens, and hundreds have been installed at our shop. On newer cars, I always insist on a professional installation by a electrical specialist - not just a mechanic.
    Nov 2003
    Welland
    Oh, i know its installed correctly, they just never explained I had to do that when I went to pick it up, and I was never given the instruction booklet for it. It just takes alot of getting used to to set it to use the remote.
    Bath
    Time Online: 48 Secs
    Thx, Jay
    Crappy Tire seems to put them on sale ( giving them away) at xmas....Installing them yourself is a JOKE..cant be done without a couple of specialty tools.....Getting a mechanic friend to installing one leads to them telling you to leave or returning with a quality one...I'm going to tell you what I do..I go start my Jeep...I go back in the house...check weather...tell wife I love her...kiss the kids...and get back in my now not so frosty Jeep....Its Canada..Its Cold..Suck it up
    Quote Originally Posted by Crackerman View Post
    I'd have to disagree. We put hundreds of these things in every year at CT and have a very low defect rate with the units themselves. Not to say it never happens, of course, but it's quite rare. The installation itself is far more likely the culprit than the module.
