Thread: Brake problem...
    Brake problem...
    '00 Intrepid, 4 wheel disc. 170k
    Very little braking - 3x+ stopping distance
    New front rotors & pads, old rears at 50%. Rotors semi-glazed, knocked down with a die grinder & 120 grit disc. Booster holds vacuum after shutdown for a few seconds. Pedal will drop when started (assist). Very slight vacuum noise when applied. Pedal applied hard, all wheels lock (in the air). All calipers not seized, sliding fine.
    Ideas?
    contaminated rubber in the flex hoses? cheap rotors, contaminated pads (even though they are new), if the packing goop on the rotors is not fully removed the pads will be ruined. internal fluid bypass in the master? did you scuff the pads with the rotors?
    Pads were installed elsewhere. AFAIK, the machining oil was removed before the pads installed. Flex lines are good - pedal hard & pistons retract easily. Rotors appear to be decent, never had no pedal from cheap rotors (warped, yes).
    I rescuffed the surfaces of the rotors, no effect.
    Beamsville
    Had a similar prob the pads were in backwards. Not sure if it is possibe on this one just a thought
    Professional lunatic
    Found it...
    The booster is leaking on the front side. You can just hear it if the windows are shut and you in a quiet parking lot. "Hissss". It's loosing it's assist, and a big master w/no booster sucks
    Thanks for the suggestions.
