Results 1 to 20 of 22
Thread: Little tools to make life easy
    Jun 2004
    in a van by the river
    Time Online: 1 Day 12 Hrs 54 Mins 25 Secs
    Have you guys ever made a special tool to make things easier while you are building something? I saw a cool little gadget that I am going to modify so I can weld on endcaps. Basically it is an L shaped bracket with a hole drilled on the short side and a bolt tacked to it. It is then clamped to the end of a tube so you can tack an end cap on it. It allows you to have your fingers away from the work, so you can set the piece in properly. These here pictures, show what a bike builder did to solve a problem.
    Welded a socket onto a flatbar for a cheap serpentine belt wrench, Don't need no damn 150.00 tool.
    Magnets work for end caps or tacking a scrap bolt to em first, no need to get all fancy with spiffy tools.... Show off
    kirkfield
    Time Online: 2 Days 12 Hrs 43 Mins 48 Secs
    Avg. Time Online: 12 Secs
    i was at waggy's the other day and he had a sledge hammer head on a broom stick .. i didnt ask
    does not play well with others
    Jun 2004
    Quote Originally Posted by anthony View Post
    must be for the dirt that won't move with a normal broom
    Near London
    Time Online: 1 Day 7 Hrs 50 Mins 4 Secs
    Anthony where's the front view of the gf? LOL. Seriously. Anyone make or is there a tool that will safely press the seals into the inside of the d30? Let's see pics of it in action.
    Bring back the Cherokee http://www.petitiononline.com/Cherokee/petition.html
    say what you want about my wife, leave my jeeps out of it.
    93 HO, 4.5" skyjacker lift, taurus fan, H4 lights, champion 8000lbs winch, custom home made front bumper, rear hitch, 136 amp alternator, 5-90's full mains set replacement with main fuse. High idle on switch, rear cargo area full extension drawer cabinet. Dual Batteries, Sanden oba and removable doors.V8 ZJ tie rod replacement with OTK insert.
    Jun 2004
    how about a block of wood????
    Quote Originally Posted by tkjeeper View Post
    two people, long bar to slide down the tube, and a piece of pipe at the end that matches the size of the seal, then whack....sorry, TAP the end of the bar till it's set in place. sorry no pictures
    Campbellton
    Tired
    Time Online: 1 Day 9 Hrs 10 Mins 15 Secs
    I can't find any pics of how I pressed the seals into my D30 axle but I can tell you how I did it.
    Its not an original idea, I read it on the web somewhere but can't seem to find the link. Once I had the old seal out of my YJ's D30 axle I placed the new seals in place and used a long threaded rod and a few nuts & large washers, large enough to cover the seal. You pass the threaded rod through the axle tube & seal and tighten down the nuts till the seals are in place.
    Its a much cheaper way than using an actual seal press tool and far gentler than wacking, sorry, I meant tapping the seal in place.
    just my two cents...take it for what its worth...
    95 YJ, RE 4" lift, 33" Procomp Extreme M/T's, Warn M8000 and mud - Trail Queen
    04 Liberty Sport, 2.5" Rusty's lift, ProComp LT245/75R16 AT's & a pair of Hella 700FF Lamps - Highway/Trail Ride & sometimes tow rig
    ^LOL, i'm sure you are right!
    Aug 2003
    Time Online: 1 Wk 3 Days 18 Hrs 58 Mins 30 Secs
    Avg. Time Online: 53 Secs
    anyone ever use a Welding Finger, or welder's finger?
    Great little tool, i use them all the time.
    I have a picture somewhere of a "finger" holding a
    loonie on it's edge on top of 1" tubing, I'll try and dig it up.
    Meanwhile here's a pic that shows what i'm talking about,
    hope it's big enough.
    D.
    "..cut my deck to the queen of spades,
    but the cards were all the same.."
    Jun 2004
    great another tool to make
    nfld
    Time Online: 2 Mins 36 Secs
    i made a dana 44 hub nut socket , id get pics but id say you all know what it looks like
    1999 WJ 4.7v8, np231, hp44/ford9" and some other stuff
    soon to be: hp d60/14 bolt, 231/300 tcase . 39.5x13.5x16 IroKs
    Avg. Time Online: 28 Secs
    what is the welding finger for??
    love my 2.5
    Jun 2004
    Quote Originally Posted by WuMark View Post
    its another type of securing device.
    Where ever I can wheel
    Time Online: 23 Mins 18 Secs
    For the life of me I can't remember who sold this, but now that you have a pic, you should be able to fab one up.
    2K XJ - 6" lift with 33s (No cutting) - See Full Specs
    1998 XJ Laredo stock
    XJ owners, visit us at www.soxja.org Southern Ontario XJ Association
    Aug 2003
    It's really good for holding small parts that you can't put a clamp on.
    Keeps your own fingers out of the heat.
    When I find that loonie picture, you'll be able to
    see it better, i think it's at work.
    Aug 2003
    Welding finger in action
    Oct 2002
    Caledonia, Ontario
    Time Online: 1 Wk 6 Days 23 Hrs 25 Mins 50 Secs
    I find this one helpful on many jobs. GM calls it a J-tool. What it is, is a swing-press. Good for swing-pressing in bearings, seals, bolts that don't fit properly, etc.
    It's also good when things go hopelessly wrong, and instant gratification is required.
    What can I say, I'm Skitarded...
    Aug 2003
    I have a few of those,
    always thought it was called a precision adjustment
    tool. Millwrights call it a "persuader"
