Results 1 to 3 of 3
Thread: rear bumper
    Jan 2006
    Pembroke ON
    Time Online: 1 Wk 2 Days 10 Hrs 16 Mins 14 Secs
    Avg. Time Online: 46 Secs
    rear bumper
    Just started my bumper today. Goal was cheap, strong, effective winch bumper. Think I am on the right track. Tried cutting with the plasma but wouldn't go through the 5/16 steel. Ended up doing all the cutting with a 4.5" angle grinder with some cut off discs.
    bumper main piece is 4x6 angle 5/16 thick, D ring mounts each end are 3/4 x 3 flat bar, and then the receiver in the middle. Also going to use the cut off from the angle iron as gussets for the winch.
    top view
    side view
    bottom view
    just have to do a little more grinding, drill the shackle holes and receiver hole and then weld it together. Might change the gussets around too, they look pretty square
    Looks good so far. Might recommend some additional gusseting around your receiver too. Those are some hefty gussets you've got on the sides; are those the recovery mountings?
    nfld
    Time Online: 2 Mins 36 Secs
    your post is named "rear bumper", so your having a winch on the rear as well??? how will you get the tail gate open???
    1999 WJ 4.7v8, np231, hp44/ford9" and some other stuff
    soon to be: hp d60/14 bolt, 231/300 tcase . 39.5x13.5x16 IroKs
