Page 1 of 5 12345 LastLast
Results 1 to 20 of 96
Thread: XJ Sheet steel bumper
    Dec 2002
    flatlands of Belle River, ont
    Time Online: 9 Hrs 7 Mins 51 Secs
    Built up this bumper for a friend, after seeing the response to the other bumper posts figured some of you guys would want to see this.
    Here is what it started as
    95 ZJ 5.2L, Custom long arm 4 link Rear 3 link panhard front. D44/9" 4.88's locked and spooled,37x12.5 MTRs, 1 ton steering, Currently bumperless but rolling.
    Dec 2002
    more
    Dec 2002
    assembled
    Attached Thumbnails Attached Thumbnails Bumper in pieces 5.JPG   Bumper in pieces 4.JPG
    Dec 2002
    mounted and winched
    Attached Thumbnails Attached Thumbnails bumper complete installed 3.JPG   bumper complete installed 4.JPG
    Dec 2002
    still needs to be finished welded, but almost there, have to do that tonight
    Attached Thumbnails Attached Thumbnails bumper complete installed 1.JPG   bumper complete installed 2.JPG
    Dec 2002
    let the flaming commence
    let me know what you guys think, the owner likes it, he didnt have to cut anything but it is very close to the grill (read: just touching)
    about that time
    How thick is the steel you used?
    Belle Riviere, Ontario
    Time Online: 3 Hrs 51 Mins 55 Secs
    That did take long to get a response. He made this bumper for my jeep.
    this was the "prototype" bumper for this design. the top shelf and front formed pieces are 1/8" but will be 3/16" in the future. the frame rail mounts and all bracing on the inside including the winch plate are 1/4".
    marcus
    94 cherokee
    449 spool/spool
    513 yukon
    custom laser cut front winch bumper
    Leather Seats & Wood Grain dash Baby!
    and more
    Dec 2002
    i cant even eat dinner without you hijaking my thread eh marcus
    I'm going to burn that sucker shut now, we will see how much stronger it becomes all sealed up.
    I actually could make both versions, one out of 1/8 for the people looking to stay light (read : 86 lbs)
    and one of the heavier stuff prob over 100 lbs easy.
    we will see
    Bradford
    Nice work
    newmarket ontario
    Time Online: 3 Wks 2 Days 18 Hrs 5 Mins 27 Secs
    Avg. Time Online: 1 Min 57 Secs
    looks very nice...how much dough would you make a replica for?
    S.S.O
    OF4WD#4900
    1990 XJ Cammed 4.0L/AW4, 4" Skyjacker coils w/2" spacer, BDS adjustable arms, Adjustable trac bar, Rugged Ridge steering5.5" RE leafs, custom front and rear bumpers, D30 lockrite, D35 W/Disc brakes,XTREME stop rotors, Hella 550's, OBA, 33"MTR'S LOTS OF STICKERS!!
    Looks nice, basically like mine, just more finished, but 1/8 seams a little thin to me for a winch bumper with recovery points on it. How is it reinforced?
    Other then that, clean quality work!! Nice detail in all cut pieces.
    Tottenham
    Avg. Time Online: 5 Mins 14 Secs
    looking good but I wouldn't go with less then 3/4" plate for the frame/recovery points and 1/4" (min) plate for the rest, with a bent plate or channel design for the main winch support.
    Also nice job on the cutting but I think you have cut out more material then necessary with out adding any reinforcing.
    Good luck and don't take this personally... just some constructive criticism
    S.S.O.
    OF4WD
    Dec 2002
    I take everything heading my was as information, and constructive criticism.
    Opinion is what makes the world go around.
    I personally do not see a reason for the 3/4in plate for the frame/recovery points considering that the frame rails on a cherokee are only stamped steel, either single or multi layer at some points.
    The bumper is held on with 6 bolts on the steering box side, and 5 bolts on the pass side. 3 bolts pass all the way through the frame rails at the steering box and then the three stock bumper bolts. On the passenger side there are the 3 stock bumper bolts and then 2 others that pass through the frame that are bolted on the inside.
    Some of the material that you see cut out is there to keep the bumper light, and to have it fail when you get in a car accident or hit a tree traveling at a high rate of speed so that the bumper fails and not the frame rails. If i made it all solid there would be no deformation and who ever got hit with the bumper in an accident would get impailed by the two mounting brackets.
    for JKmotorsports -> In one of the first pictures you can see that the mounting brackets at the frame extend all the way to the recovery points so it is one complete unit, the 1/8in does not hold the force of the pull point, it only adds to it and is mainly there for grinding off stuff and protecting the winch, the 1/4" frame bracket was designed to hold all the force and then the winch plate was designed to tie the two sides together.
    Any more comments or suggestions please let me know,
    side note, the next bumper will prob be made with 1/4" and 3/16, instead of 1/8, this was a prototype.
    In all honesty I would like to hook up an 8000lb winch with a snatch block coming back to the rig, put it up against a tree and snatch it off of another tree and see if the winch will stall before the bumper will fail. There is a safety factor built into the bumper but real world, is real world.
    Bradford
    Dec 2002
    you also cannot see that the eyelets are doubled up with another piece of 1/4 where it extends up from the bumper.
    all that plus this is a functional bumper for the weight it is. If i design one from 1/4 it would be indestructable but also like 200lbs.
    Tradeoffs always have to be made somewhere.
    Bradford
    Dec 2002
    the nuclear waste depository
    Time Online: 1 Wk 1 Day 13 Hrs 17 Mins 56 Secs
    Avg. Time Online: 42 Secs
    perfect just perfect
    thats coming from a mechanical designer that understands strength and thickness are not dependent.
    11 F150 tow rig/ DD
    87 Sami buggy
    99 XJ RIP
    91 XJ RIP
    86 CJ5 RIP
    3/4 is just retarded heavy for no reason, 3/16 is plenty for most of it except the winch mount and shackle mounts.
    Dec 2002
    That is my opinion on the thickness matter.
    thanks for you input.
    Tottenham
    Quote Originally Posted by Black88YJ View Post
    Bradford
    No your right I couldn't see that the recovery points were doubled up...
    the idea of cutting out the steel to make crumple zones, is a good idea for a DD and never thought of it.
    your right there are tradeoffs to be made somewhere... I just like to make things indestructible
    Mar 2003
    brampton
    Time Online: 5 Hrs 21 Mins 5 Secs
    Well I think it looks good.....and thats all that should matter for I am Tugger lol
    sorry....but I like it
    good job and well thought out by the looks/ sounds of it
    PITBOYZ WILD CHILD
    PITBOYZ BRAMPTON CHAPTER (PB4L)
    OF4WD member # 2543
    www.Pitboyz.ca
    TEAM MOTIVE MEDIA
    God made all people..... and Smith and Wessen made them equal.
