Page 1 of 6 123456 LastLast
Results 1 to 20 of 112
Thread: JKM XJ Build
    JKM XJ Build Update
    So I'm ever changing this Jeep so I fiqured I might as well start one of the "Build" threads and trust me it will be ever changing.
    So here it is:
    91 Cherokee Limited
    4.0L AW4 w/AWShifter (Love it Offroad!!)
    NP242 GoJeep SYE Setup
    8" Skyjacker Softride Coils
    SkyJacker Leaf is 1" Blocks and 1.5" Shackles
    BDS Shocks
    JKS Discos
    Hiem Jointed DIY Trackbar
    D30, 4.10's LockRite
    Ford 8.8 Detroit Locker
    Homemade(Not Finished) Winch Bumper
    Champion 8000lb Winch (solenoid move under hood, greased and serviced to prolong life)
    Gutted interior, Summit Racing Poly Seats (EASY to Clean!!!!)
    14/35 Ground Hawgs (soon to be grooved) on 15x10 Eagle Alloys
    OBA using A/C compressor
    2x5" Tube Rockers also serve as Air Tanks
    Bored TB and Spacer
    Dual battery, 136amp Alt.
    Dual Elec Fans
    Cut fenders(Really cut!!! Bumpstops only extended 2" over the shortest Factory Bumpstop on an XJ) w/TJ Flares
    Probably more I'm Missing!
    To Come:
    OTK Hiem Joint Steering w/ Hydro ASiist (99% done but got to do it right!)
    Front Long arms (got the Johny Joints, need the time)
    Rear Traction Bar (need the crossmember from the front)
    Finish Front Bumper
    Rear Bumper and Carrier
    Finish plating the floors (StupidRust!!!)
    Tube fenders (Wider/Stronger)
    Better Front Axle (Trying to sell some 5ton Rockwells, what do ya think?)
    Supercharger(was thinking turbo becuase I have built 6+ setups for customers, but SC is better on the trail)
    Sorry for the long list. I've owned this for 1yr after building many imports for me and others and have done 75% of the work on it (Bought it with 31's, slight lift and the 8.8 basically!) about 1 month after buying posing on top of my old winter beater which the XJ Replaced.
    We are also starting to build a chopped 98 Sidekick 4dr. going for 33's, Solid Front axle, 3 or 4 link and supercharged(as it can't turn 33's in the mud on the 1.8l!!!) Look for pic here too!
    Lambton Shores
    Amazed
    Time Online: 4 Wks 19 Hrs 57 Mins 51 Secs
    Avg. Time Online: 2 Mins 22 Secs
    looking good... i like the TJ flares on it.
    YouTube Videos
    98 AM General Hummer with 2" lift and 38" Tires
    1982 Suzuki LJ80V - Pretty much stock other than a light bar and some lights... lots of mods to come
    Niagra on the lake
    Time Online: 1 Wk 1 Day 9 Hrs 19 Mins 20 Secs
    Avg. Time Online: 41 Secs
    when u groove those tires i would love to see the end result thinking about groving mine
    1990 Cherokee 2dr, 38's, toyota axles, 488's, welded front and rear, D300, Square driveshafts, Riding on leaves.
    southwestern ontario
    Time Online: 1 Hr 19 Mins 38 Secs
    It's come a ways since our Bobcageon tour...looks good man...mine has changed too.
    Why am I not surprise Ian. You gonna guide us around Bob this year?
    Avg. Time Online: 28 Secs
    i like your bling diff cover haha
    i cant wait to see how you groove those ground hawgs. are you going to redesign the whole tread pattern or just minor adjustments?
    love my 2.5
    Ya bling diff cover came on it, but it's is thicker then stock.
    Haven't decided on the Groove Pattern. Not to many pics of others grooved as they aren't as popular as TSLs or Boggers. I'm at least going to seperate the center lugs from each other and the outer lugs.
    iv seen a couple pics, they have killer potential. is it 8'' of lift still on the short arms? if it is im just wondering how it rides on the road, any bumpsteer or wandering?
    twin2626 Guest
    Nice XJ, what year TJ fenders and how hard are they to install??
    newmarket ontario
    Time Online: 3 Wks 2 Days 18 Hrs 5 Mins 27 Secs
    Avg. Time Online: 1 Min 57 Secs
    looks funny without the long arms.. kinda like mine... how do you like the skyjacker springs? im deciding between them and the RE stuff
    S.S.O
    OF4WD#4900
    1990 XJ Cammed 4.0L/AW4, 4" Skyjacker coils w/2" spacer, BDS adjustable arms, Adjustable trac bar, Rugged Ridge steering5.5" RE leafs, custom front and rear bumpers, D30 lockrite, D35 W/Disc brakes,XTREME stop rotors, Hella 550's, OBA, 33"MTR'S LOTS OF STICKERS!!
    Yes short arms. But with the weight of the front bumper and winch I probably net 6.5". Yes it wanders, Yes I get a lot of unloading on hill climbs. I've had the JJ's since December, just need to find time to fab the longarms.
    TJ Flare? Don't know what year, there from a TJ so what years are that 97-05? I don't know. Yes they are a lot of work if you do it like I did. I followed this first but ripped the rear off many times. http://www.tcinternet.net/users/jkor.../tjflares.html
    My rear has almost 4" cut out of the rear, so I fabbed all new fender liners, and welder a lip on the quater panels to rivet the flares to as the plastic that they normally mount with tore off(I run alot of narrow trails)
    I plan on doing Tube fender with 1/8" plate on the front fenders and rear quarters for more protection.
    And as for the springs, I had reqular Skyjacker with spcaers and hated how it rode. Flexed alright, but could be better, So I went with the Skyjacker softrides and LOVE them. I have flex them to much yet, but I know the will be better.
    Update: Grooved the tires a bit.
    GREAT Tool. Cut the treads like butter!!!!! Would Suggest it to anyone.
    And Testing them:
    New Hydro Assist Steering. Good Bye Death Wobble!! I love this setup. NEVER has my jeep felt so crisp and nimble on the road, virtually all the float is gone. I have a slight wobble at 90kph and above, but me steering column is broken form the shock from the death wobble, and my ball joints have seen better days.
    Nestleton
    Time Online: 2 Wks 2 Days 15 Hrs 14 Mins 19 Secs
    Avg. Time Online: 1 Min 22 Secs
    damn that looks beef
    1.5" OD .25 Wall with a 1"OD .25wall down the center and plug welded all along. She weighs a bit, but I can bash it all I want and I think the 5/8" Grd. 8 hardware will shear first.
    Paradise, Newfoundland
    Psychedelic
    Time Online: 1 Day 2 Hrs 49 Mins 33 Secs
    Overbuilt, I like it.
    I want a Grand Wagoneer!!
    03 Tracker LT - DD
    96 Talon TSI AWD - Jack Stand Queen That's Almost Running Again
    08 JK Unlimited Sahara - 2.5" BB, 33" BFGs (Hers)
    Overbuilt? It's a jeep, can that happen? My Hydro Cylinder is a little smaller then most use, but if it bends I have another sitting aside from our snowplow that I didn;t realize was in our shop.
    I REALLY like turning 35's while against a snowbank with 2 fingers!!
    New rims. Well sorta new. Went to my machinest to get the rings cut but he had some file problems and couldn't open them. I'll get them tomorrow with a new file.
    Cheap 15x10 Wagon Wheels (thanks Cherokee Steve)
    And my final beadlock design. 32 1/2 Bolts. Scalloped to clean mud better.
    Psychedelic
    Nothing wrong with overbuilt.
    Time Online: 20 Hrs 15 Mins 21 Secs
    lookin real good man.. real good
