Results 1 to 20 of 20
Thread: weird grinding noise ?
    Mildmay
    Time Online: 4 Days 17 Hrs 42 Mins 25 Secs
    Avg. Time Online: 23 Secs
    well i got a 95 avenger, it a auto 4clyinder.... and was going to go out and eat some supper when i heard this werdi grinding noise from the passenger side.....
    i drove the car eariler but it never made no noise at all before... and it only does it when turning to the left, but to the right it nothing and ito nly makes the noise around 30km then alitte after 30km it gets a little quiter when making the noise.. anyone have a idea what it could be ??
    need to get this figured out as it my DD and i need it....
    I Like My Women Like I Like My Jeeps..... Wet And Dirty!!
    89 YJ Islander 4.2L, SOA d30/d44 lock rite locker, tj shafts/297 u joints, 35x16x15 boggers, custom wrap bar, 15x10 american racing rims, AA SYE, Warn 8274, custom front/rear bumper, fog lights, teraflex high steer, 1 ton tie rods ends, 40 series flowmaster, leather xj power seats - SOLD!!
    81 camaro, TH350, 468BBC - SOLD!!
    Apr 2005
    Niagara Falls
    Time Online: 3 Days 8 Hrs 52 Mins 56 Secs
    Avg. Time Online: 16 Secs
    wheel bearing or cv joint
    PitBoyz
    OF4WD #3203
    1978 CJ7, 350 EFI, T18, D20, D60/D60, 5.13s, Detroit/welded, 38" TSLs, Hummer H1 rims w/beadlocks, SOA on RE springs
    If I wanted serious, I'd be at work.
    Mildmay
    i was thinking the cv myself as well but wanted to other opinions on it...
    i dunno if it be the bearing as usually they have a sign before they go they start to hum, and there aint no hum or anything just a grind almost like a stone is rattle around or something in there....
    May 2005
    Blind River
    Time Online: 1 Mth 3 Wks 2 Days 8 Hrs 45 Mins 55 Secs
    Avg. Time Online: 4 Mins 23 Secs
    sounds like the muffler bearing
    proud OF4WD member #3875
    Mildmay
    Quote Originally Posted by caged View Post
    damn why didnt i think of that rog??
    not sure if it applies to that car, but strut bearings can make a grinding noise.
    Mildmay
    but the thing i dont get is the fact that it doesnt make the noise ALL the time only around the 30km range and only when turning to the left.... which i thought was weird it onyl does it around 30km.. then it get a wee bit quieter when u speed up more:confused:
    in my cavalier the rubber isolator in the coil spring cup is worn or misplaced so when i hit a bump or turn a certain way it makes this shitty metal on metal on sand and crap noise. I sprayed oil into there and it stopped.
    Mildmay
    ya mine dont have like a coil type suspension, it like a strut without a spring i think... i would have to go look again tho to double check...
    Barrie ON
    Time Online: 3 Days 10 Hrs 33 Mins 41 Secs
    Take the wheel off and see if there is any visible scratches or areas that have had something grinding on it. Check to make sure everything is tight and greased. If everything looks good my guess is the CV joint, maybe a ball joint or something in the hub assembly. Good luck
    2009 Subaru WRX STi
    R.I.P. 2001 Grand Cherokee 4.7L
    R.I.P. 94 Grand Cherokee 5.2L
    Mildmay
    ya took off the tire and checked her out and everything seems to be in ok order.... and the cv shaft i thought maybe it would have play if it is done, and will it aint got no play maybe a wee bit but thats normal.....
    was gonna take off my caliper and see if there was maybe a stone in there or something but the damn bolts are on so friggin tight i couldnt get enough leverage on them with the breaker bar since it in my drive way LOL...
    Apr 2005
    thornhill
    Time Online: 6 Days 58 Mins 25 Secs
    Avg. Time Online: 29 Secs
    this is the most stupidist dumbist comment i have ever heard , how could you with a good conscience tell someone that , this is rediculous and insulting and foolish and actually pisses me off . how could you tell someone the muffler bearing is gone on the front of the car . this makes me sick . the muffler bearing is clearly at the rear of the vehicle ..
    Quote Originally Posted by 89_Jeeper View Post
    UM a strut is a strut because it supports the COIL SPRING.
    PS. if the spring is not supported in part by the body of the strut, the strut is a shock.
    Quote Originally Posted by C.C. View Post
    well, could be a modified strut like old fox body mustangs, suzuki sidekicks etc...
    Mildmay
    i'll have to have a look at it again today and see what kinda strut/spring setup is on the car....
    thessalon
    Time Online: 1 Wk 23 Hrs 54 Mins 50 Secs
    Avg. Time Online: 39 Secs
    Ill bet its the cv
    they usually start to go when your noticing the car turning and its a grind/clunk, my mazda did it and my 95 avenger did it, replaced cv and fixed the problem, they are not cheap to replace if you wont tackle it yourself but Im willing to bet its the cv
    May 2005
    Blind River
    yeah, id say for sure it's the cv joint.
    grab one from a wrecker with low km's or spend $$ on a new one. they're not cheap.
    waggy, i thought they just put the body on backward to change these to front wheel drive. hmmph, my bad.
    Mildmay
    yea, the cv axle's arent much....CT says reman is 89.99, and then the new one is 129.99 with core's.....
    Palmerston, On.
    Time Online: 6 Days 14 Hrs 36 Mins 10 Secs
    Avg. Time Online: 32 Secs
    Well the horse is getting pretty beat up but I'll put in my lash on the cv.
    Tim
    '98 XJ 2dr. 3" and 33" ATs --His--
    '99 XJ 4dr. 3" and 31 AT's --Hers--
    '72 J4000 --Ours?--
    It's all good.
    Quote Originally Posted by waggy View Post
    Hahaha!
    I started reading this, thought "Who the F--- is this guy?... " then kept reading.
    Nice.
    I'm leaning towards bearing if the CV isn't torn. I've seen all of 1 CV joint go internally (bearing race cracked) without the boot being split first in 10 years of wrenching for a living. But, I'd try a wrecker axle first (keeping yours as a spare), and if it don't work you're not out much for the test.
