Thread: TJ Build
  1. #2161
    Apr 2004
    Grimsby, Ont.
    Avg. Time Online: 9 Mins 18 Secs
    I have no clue what she would weigh, but keep in mind anything over 900KG requires a safety.... so I'd say she weighs 900KG.
    #20OF4WD#3476
    "Will roll over for treats"
  2. #2162
    What's the guess on weight of mine after a couple lengths of 2 x3 1/4 wall. Or what should i tell them?
    You are pretty hard pressed to have the average 7K tandem axle car hauler weigh in excess of 1500 LBS (680 KG) empty. The very heaviest typically don't get to 2000 LBS (907 KG).
    Regardless, your trailer weighs under 900 KG. Just tell them it weighs 800 KG and leave it at that. It is an arbitrary number, anyway, since nobody that matters really cares what it weighs empty. The green hornets salivate over the actual loaded weights and the magic 4500 KG threshold we have beat to death here.
  3. #2163
    Feb 2005
    Simcoe
    Time Online: 1 Mth 1 Wk 3 Days 15 Hrs 38 Mins 51 Secs
    I registered my car trailer as home built as well. Like everyone saying number of axles, color, weight.
    Nice score on the trailer. I would think you will need fenders. What are you using for the deck? There goes your $200 budget LOL.
    Are you still wanting going to grab the truck camper?
    92 RENEGADE
    82 Toyota long bed
  4. #2164
    Quote Originally Posted by Pippilongstocking View Post
    Perfect, 800kg it is.
    Quote Originally Posted by PRIORITY 4 View Post
    Gonna widen it a bit where the tires sit for the full widths and maybe bolt down some wooden 2x8's just inside the frame rails. Doing some measurements it's a bit of an odd configuration having a longer front end then rear so i'll probably keep the length as it is. Leaves some decent room up front to build a little storage box at some point for parts, welders, genny, dead hookers and what not.
    Still liking the camper idea buddy. Once i get the Ferd on the road i'll let ya know
  5. #2165
    So for the most part i have everything in plumbed and wired. Made some driveshafts last night out of various ends and new tube, just need a couple joints so i can install, spin check/adjust and weld. Having a bitch of a time finding 3/8" fuel line that's rated over 50 psi. I have some 50 psi line in now but should probably swap out sooner then later. Have ignition to a switch as well as starter. Starter cranks good and proper pressure adjusted to the rail. But.....waiting on a friggin gas pedal/tac module to show up i ordered off ebay. Seems to be lost in never never land. I thought maybe it'd start without but no dice. At least i hope that's why it won't.
    A couple pics. Everything is so damn tight with the rad lean.
    With the fancy cock bracket and a new frame mount my steering shaft has more clearance then it ever had. This worried me from the get go. Also have a sneaky little PSC pump in there i jacked from the neighbor when he wasn't home. lol
    Need to mount the computer and clean-up wiring but gonna wait till it fires before i go too far. Added a little more A pillar support as well and a no charge B&M.
    More wiring to tidy, temporarily permanent battery tray, chopped stock intake tube/abortion which ended up fitting mint. Just needed to plastic weld a couple holes up and need to sort a way to toss a 90 and extend the filter. have the fans mounted off some removable brackets to the rad mount.
    And i coughed up and grabbed a couple proper 32 spline flanges for the 205.
  6. #2166
    The rad has a wicked gangster lean. Too bad the steering box is in the way of being able to lower it.
  7. #2167
    Avg. Time Online: 1 Hr 4 Mins 23 Secs
    What he said ^^^
  8. #2168
    You shut your full hydro mouth! lol
  9. #2169
  10. #2170
    lol
    And seeing as mine is not done for this beautiful looking 24 i'll just jack the next best yard heep. It's not a 6L but i guess the 5L will do. Pulled it in last night for a once over. A lot smaller list! Chop off windshield and add plexis, make front shaft, add limiting straps, new steering pump, wire winch, jack some beadlocked 42's, and hope noisy throwout bearing survives.
    Oh ya, add safety yellow headlight bezels! lol
  11. #2171
    Time Online: 2 Mths 11 Hrs 48 Mins 59 Secs
    Avg. Time Online: 4 Mins 57 Secs
    Curious...how many times has someone fallen in that crack?...lol
  12. #2172
    Jan 2013
    Midland ON
    Time Online: 4 Mths 3 Days 7 Hrs 8 Mins 12 Secs
    Avg. Time Online: 10 Mins 6 Secs
    Quote Originally Posted by RBJeepThing View Post
    Yeah im sure its great on the ankles eh lol
  13. #2173
    Gets comfy once you really wiggle in there! Lol
    42's didn't fit safely but a new drive shaft, steering pump, a trim of my ol plexis with a cut off frame, and some paint and welds and things spruced it up!
  14. #2174
    Looks good
  15. #2175
    Just remembered, there was one ankle broken in it but not recently.
    Fun fact. The ankle that was broke was Laura, the chick that runs Silver Willow Classics car show. Her folks built the place and she grew up here. From what she's said there has been all kind of awesomeness go on in this shop. Here's one of the pics she sent us. Pretty cool.
  16. #2176
    Feb 2005
    Simcoe
    You have been a Busy busy man Curt. Looking good otherwise. My build came to stand still. I've been doing a lot destruction and not enough construction LOL.
  17. #2177
    Any luck with getting a pedal?
  18. #2178
    Yup, road trip last night for one. Plugged it in about 1 in the morning and no start. Had a few choice words and went to bed. Have a better look this eve.
    On a side note, was an interesting rednecks backyard i got the pedal from. Tons of trucks from the 60's up.
    Here's a couple yard ornaments
    Bunch of eagles
    Comanche with a sliding soft cab
    Super sweet scoop!
    And if my heep doesn't get running soon maybe i'll head back and grab this sick whip. lol
  19. #2179
    So it's finally alive! Now that i've heard it run the motivation is back, haven't touched it in probably a month.
    Those mufflers you gave me had some serious mouse nests Bernie! lol
    http://vid1362.photobucket.com/album...psm2tku8lr.mp4
  20. #2180
    Jun 2011
    Vaughan
    Amazed
    Time Online: 2 Wks 2 Days 6 Hrs 16 Mins 20 Secs
    Awesome!!! Get her done!!! Cant wait to see it in action....
    Obsessed about offroading and moved from Spain to Vaughan.
    Owner of a never ending YJ project: BUILD THREAD
    Winter beater 1998 Toyota 4Runner
    Owner of a Suzuki Sammy back in Spain
    www.d-limit.com
