Thread: TJ Build
  1. #1881
    Lol
  2. #1882
    Apr 2013
    Time Online: 1 Mth 20 Hrs 30 Mins 27 Secs
    Avg. Time Online: 2 Mins 31 Secs
    dude what is your secret to time management.
    where do you find the time???
    btw Please let this become a rock bouncer...
    Don't ask me cause I don't know.
  3. #1883
    Quote Originally Posted by farookismail View Post
    Plasma cutter. Lol
  4. #1884
    Apr 2013
    i know its money but that cage was build for a body now there is no body so maybe time for a new design. just a thought
  5. #1885
    Some of the cage is getting cut up and changed a bit, also lowered a hair. We'll see what happens, kinda just playin it by ear. lol
  6. #1886
  7. #1887
    Time Online: 10 Mths 3 Wks 5 Days 11 Hrs 48 Mins 2 Secs
    It will be simpler and cheaper to just go full hydro and be done with it. Piecing together a drag linked servo with a double ended ram will not be cheap and from a performance standpoint, is not netting you anything extra in return.
  8. #1888
    Word from the wise as always! Pretty damn cool tho for the racers that need mechanical
  9. #1889
    I'm not so sure about that but I'll go with it. lol
    It is...and meets to mod class rules perfectly. It's just a fair bit of work with additional costs. And you would still be stuck with a box in addition to a servo that is hard to package on a linked Jeep. Straight up full hydro is just a very simple and elegant solution to all of the steering shortcomings, including packaging. The mod class would run full hydro, like the unlimited class, without the servo/box if the rules allowed that.
  10. #1890
    Little work this weekend. Gutted and trimmed up the rotten firewall/cowl. Plans are and it looks like i'll be able to drop the cage down 3-5 inches.
  11. #1891
    Then stripped down a 5.3 and tranny that was laying around for mock up.
    Hungry hungry hippo'd it under and up
    Boogered together some mounts
    And slapped it in
    Temporary tranny holder. lol
    Front clearance
    And
  12. #1892
    What's the plan for tcase?
  13. #1893
    I have a flipped and sticked 300 so I'd need an adapter. Or be a cheap ass and run a dodge 241. Lol
  14. #1894
    Homemade doubler? Trail less travelled has all the drawings.
  15. #1895
    Not a doubler. It's the DEO (down east offroad) flipped and sticked 300. Can't remember if it ever got the 32 spline treatment. My wheeling style doesn't really require stupid low. Would be a cool option but i have bigger fish to fry. I will however require an adapter and it appears i have options from Novak or AA. Hmmm.
    And I had another hearty night of cleaning and organizing. One more good evening and the place should be tip top. So.........much..........shit!
  16. #1896
    I'd be leery of you + 6.0 + D300.
    You would be running on the ragged edge of what that case will put up with. Some have good success with them and others, not so much, Once you put both 32 spline outputs in, the input and the housing become the weak links. I would not throw too much money into one to get it to live in your application. I think you would be better off with the 241 in the short term - cheap and very strong.
  17. #1897
    Might be a 5.3. We'll see what pans out. If it's a 6L i will likely run the 4l80 that would come with. It appears as tho you are correct, 241 is bolt on for both (come in 27 and 32 spline), stronger and i can get an SYE for a little cheaper then the 300 adapters. Or run no SYE for now depending. My brain is starting to hurt. lol
  18. #1898
    If you have the driveshaft length, you light be able to skip the slip yoke eliminator. Though, it is rather large on the 241. I'd stick with the 241 for now. It will still be stronger than a 300 with a bunch of dollars thrown at it.
    Another thought if you want to go completely stupid for cheap is a 271. It is a beast and probably not too far behind in strength than even a 205. I'm just not sure if a TJ frame is wide enough to accommodate it.
  19. #1899
    Damn you. I can make space. Back to google i go. lol
    Edit - No dice on spline counts and that things friggin retarded. lol
  20. #1900
    I think organization helps motivation
