Thread: TJ Build
  1. #1921
    Time Online: 10 Mths 3 Wks 5 Days 12 Hrs 22 Mins 10 Secs
    You could build a set of headers. You get everything placed exactly where it should be, you choose the correct primary tube diameter and place collectors where they need to be. It's a lot more work but worth it. It isn't hard work - just a little tedious. I ended up building a set headers for my heep. It just made the most sense to get everything fit properly and not be stuck with a shitty flowing set of folds.
  2. #1922
    Feb 2005
    Simcoe
    Time Online: 1 Mth 1 Wk 3 Days 15 Hrs 38 Mins 51 Secs
    Hey Curt, I have Hooker shorty headers in my set up, collects into 1 muffler and dumps on the passenger side. I'm not running CATS. I can take pics if you want.
    92 RENEGADE
    82 Toyota long bed
  3. #1923
    Guelph
    I'm not sure if the gen 1 350's (pre 1970 old school) will have the same exhaust mounting as your motor but, there are all kinds of different dumps you can get for them.
    Maybe something like this would work. It already has the turn back for you and should allow you to get clearance to send it off what ever way you want to go with it.
    http://www.monsterautoparts.com/CHEV...manifold_4.htm
  4. #1924
    Cylinder heads, exhaust ports, etc., are completely different on gen 3 and up engines and not backwards compatible with the Gen 1 and 2 stuff.
  5. #1925
    Companies like Cone are a great resource for everything to custom build anything to do with exhaust. They have a ton of DIY header kits. The sell flanges, collectors and merges as well to complete the kit. http://www.coneeng.com/tubing_and_bends.html
    When I built mine, I just bought what was called a 'box of bends'. It was just a large box of random bends with various lengths of tube and then bought head flanges and collectors. I also skipped the traditional collector flanges and used V-band clamp flanges instead. They are not cheap but you get the perfect union that never leaks and disassembles quickly and easily without the need for any type of gasket.
    There are a lot of companies that offer DIY header options. If you have a race car shop near by, they can probably hook you up or you can order everything online.
  6. #1926
    Quote Originally Posted by PRIORITY 4 View Post
    Lets see a couple pics Bernie
    Quote Originally Posted by DWG View Post
    Yup, don't think gen 1 works
    Yup, thinking building could be a fun little project. It seems all aftermarket are using 1 5/8" x 0.065. Could likely just do all my own bends in 1 3/4, buy a couple collectors and plasma up flanges. That would be nice and cheap! lol.
    Still on the hunt for a 6L, tranny and tcase!
  7. #1927
    You may want to think about the bend radius requirements of your header tubes. The radius requirements can frequently be very small and much tighter than what most home use benders are capable of bending.
    You can buy tube kits in any primary tube OD that you like. 1.625" is fine for a 5.3 but a decent 6.0L will make use of 1.75" primaries
  8. #1928
    Quote Originally Posted by countryboy View Post
    Missed your post. That is tight. Looks good but still wouldn't work for me. And put a little heat shield on that motor mount. lol
  9. #1929
    So i have a buddy that can laser the exhaust flanges. I can buy collectors. I think my bender minimum is .095 for my 1 3/4" die. All the aftermarket seem to be 1 5/8 with .065 wall. That works out about the same ID for flow. Just not sure if my bends will be tight enough. think its 5.5 CLR. Hmmm. lol
  10. #1930
    Feb 2005
    Simcoe
    Hey Curt, here are the PICS, sorry for the delay.[IMG]
    href="http://s1079.photobucket.com/user/PRIORITY4/media/Mobile%20Uploads/20151128_113308_zpsca7zi4cg.jpg.html" target="_blank"> photo 20151128_113414_zpsu0ni1ir9.jpg[/IMG]src="http://i1079.photobucket.com/albums/w513/PRIORITY4/Mobile%20Uploads/20151128_113308_zpsca7zi4cg.jpg" border="0" alt=" photo 20151128_113308_zpsca7zi4cg.jpg"/>[/IMG]
    [IMG] photo 20151128_113527_zpscsfq2ve8.jpg[/IMG]
    [IMG] photo 20151128_113617_zpsgtvqw8q1.jpg[/IMG]
    [IMG] photo 20151128_113455_zpsgxdra2xh.jpg[/IMG]
  11. #1931
    Thanks Bernie! No chance of those fitting as is. New plan tho, might be able to get a pair of something like those no charge in the steel flavour. A little nip n tuck with some hopes n dreams!
    Waiting on a willy's grill but got a just in case cj grill. Cut my old stinger/hoop off and mocked up on the Jamaicans. Lol. Would also love a willy's tail gate. If anyone has a line on a willys grill or tail gate hook a brother up!
    With the grill, chopped hood and cowl, lowered cage my heep is getting smaller!
  12. #1932
    Avg. Time Online: 1 Hr 4 Mins 24 Secs
    Cool shot
  13. #1933
    The CJ grill looks tits.
  14. #1934
    Jan 2013
    Midland ON
    Time Online: 4 Mths 3 Days 7 Hrs 8 Mins 12 Secs
    Avg. Time Online: 10 Mins 6 Secs
    Agreed
  15. #1935
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 5 Days 10 Hrs 10 Mins 51 Secs
    Avg. Time Online: 38 Mins 55 Secs
    sweet!
    WHAT WOULD MACGYVER DO?
  16. #1936
    Ya grill is in mint shape! Still would love the stamped Willys grill and stamped tailgate. Just sent an email to willys acres. We'll see. lol
  17. #1937
    May 2005
    Blind River
    Time Online: 1 Mth 3 Wks 2 Days 8 Hrs 46 Mins 20 Secs
    Avg. Time Online: 4 Mins 22 Secs
    just don't tell him what you're putting it on or he won't sell you one.
    proud OF4WD member #3875
  18. #1938
    Oh shit I said for a project. Lol
  19. #1939
    Time Online: 1 Yr 5 Mths 2 Wks 1 Day 16 Hrs 51 Mins 8 Secs
    TJ Build
    A Willies restoration project yah.
  20. #1940
    May 2005
    Blind River
    yes, original equipment 3b restoration project. :nodhead:
    markus is a picky guy when it comes to willys.
