Thread: high beams on unless battery is disconnected
    Strathroy, Ontario
    hey got a '90 cherokee that the high beams are stuck on even if I have the lights off, they only way they will go off is if I disconnect the battery, didn't know what this would be from
    Brampton
    Time Online: 4 Mths 2 Wks 10 Hrs 15 Mins 21 Secs
    Avg. Time Online: 11 Mins 1 Sec
    It's your Daytime Running Light module, in all probability. I'm not sure where it is on the XJ, but I'd put money on it being the problem.
    Unplug it (once you find it) and life will be good. All you lose is the high beam indicator
    Welcome to the Forums.
    While it's easy to get excited about finding this place, , please use the search feature. It'll not only limit the number of repeat-questions, but you'll get your answer right away and not have to wait for someone to reply!!
    I searched and found;
    Lights will not turn off!
    Like DarkWolf said, this owner also had a daytime running light module problem.
    Nestleton
    Time Online: 2 Wks 2 Days 15 Hrs 14 Mins 19 Secs
    Avg. Time Online: 1 Min 21 Secs
    Before replacing the whole module, if you snip the orange striped white signal input wire, it will disable DRL and you keep the high-beam indicator working fine.
    JB Weld. You're my only friend.
    K-W
    Time Online: 1 Day 15 Hrs 27 Mins 30 Secs
    Avg. Time Online: 8 Secs
    ^ Does this apply to 97+?
    Nestleton
    It should apply to all TJ's - you can simply unplug the module if you don't feel like cutting things, but as stated above your hi-beam indicator may be constantly illuminated.
    Jun 2003
    Barrie, Ontario, Canada
    Time Online: 1 Day 16 Hrs 27 Mins 24 Secs
    He said he had a 90 XJ, and if I remember right, DRL's didn't come on them yet till around 93 or so, and had to be on every new car/truck by 96, So I don't think its a DRl issue, but I could be wrong... Just my thought
    "Invisible souls, leave .308 holes." ----- USMC Recon Sniper
