Thread: Turbo'd on Propane
    Aug 2005
    owen sound, ontario
    Time Online: 1 Wk 3 Days 22 Hrs 48 Mins 13 Secs
    Avg. Time Online: 54 Secs
    Turbo'd on Propane
    Thought I'd share a small part of my buggy build. This build is taking way too long , so I figured what the hell. Started my turbo header 2 weeks ago , cut out the flanges from 1/2" plate with the plasma , then drilled the holes for the ports with the hole saw etc. Taped the turbo flange and installed 3/8" studs. Used NSP weldable els for the header tubes ( 90`s and 45`s ) then I built the collector and finished welding it up. I would have cleaned it more but I`m wrapin the tubes with header tape so it aint goona be seen anyway.
    Got the header bolted up to the 22RE and plumbed the oil feed line , and the coolant lines as well. Theres more finished but I`ll save that for later.
    Few details...IHI Turbo off a Ford Turbo Coupe , fed by an IMPCO 225 mixer and a Renzo converter in a draw through setup ( no intercooler ) a fork lift donated its tank LOL.
    Attached Thumbnails Attached Thumbnails TURBO 006.JPG   TURBO 007.JPG   TURBO 009.JPG   TURBO 011.JPG
    Paradise, Newfoundland
    Psychedelic
    Time Online: 1 Day 2 Hrs 49 Mins 33 Secs
    Nice man.
    Can't wait to see that thing done.
    I want a Grand Wagoneer!!
    03 Tracker LT - DD
    96 Talon TSI AWD - Jack Stand Queen That's Almost Running Again
    08 JK Unlimited Sahara - 2.5" BB, 33" BFGs (Hers)
    Looks good. How did you select the turbo. She'll spool fast but run out of huff. It's a small turbo. Good luck with things.
    Aug 2005
    owen sound, ontario
    ^ Thats exactly why I chose this turbo , top end horsepower was not the goal. I'm looking for a fast spool to aid in low end power ( getting some wheel speed up while climbing obstacles etc , not for mud boggin lol )
    I chose to add a couple cylinders for the same reason but still on bbq juice. If I ever need more power I think a draw through system is easy and cool. Easy is a term i use loosly
