Thread: well I have bent front axle
    brownsville
    Time Online: 6 Days 20 Hrs 45 Mins 35 Secs
    Avg. Time Online: 33 Secs
    front axle for my 88 xj? -I'm having bad tire wear on left side so I took it in to the shop and the guy said I have 2 ball joints and 1 u joint that needs replacing and he said the axle is bent and would need offset ball joint so just get another complete axle a better one dana 44 or something, where do I look? I have asked around found afew axles one from amc wagoneer older one and ford dana 44 from 79 bonco but they would need alot of work make them fit in . I have rear axle already 8.8 ford w/3.55 gears going to be installed soon so might as well do front one too.
    Not much help, but swapping any non-OEM axle in is going to require fab work. Perhaps nabbing another D30 for time being? Then you can fab a replacement at your leisure.
    Jan 2004
    Thornhill / Bowmanville, On
    Avg. Time Online: 54 Secs
    We have D30s here at the yard from cherokees...
    youre welcome to come in and pull one for yourself...
    Schomberg
    those older 44's you mention are passeger side drop (i believe) you jeep is driver side drop... it can be done but alot of fabbing and you need a new t-case. look for a something with a drivers drop... save you a world of headaches and moula
    WHEN IN DOUBT... GO FULL OUT!
    PB4L
    Feb 2005
    Bradford
    80-91 wagonneers are driver's drop (eariler are pass. drop)
    http://www.universityofjeep.ca/wag_f...4_install.html
    early bronco 44's are also driver's drop
    http://jeep.off-road.com/jeep/articl....jsp?id=261446
    these threads are for Yj's, which are fairly easy swaps because they have leaf springs. XJ front requires more fabbing due to coils (still doable obviously).
    reverage on here bought a sweet prefab d44 truss that has all the mounts integrated, check his thread.
    brownsville
    thanks for all everyones help
    K-W
    Time Online: 1 Day 15 Hrs 27 Mins 30 Secs
    Avg. Time Online: 8 Secs
    Sounds more like a mechanic that knows how much these ball joints suck to change. Get a second opinion...
    Where ever I can wheel
    Time Online: 23 Mins 18 Secs
    Quote Originally Posted by got2boost View Post
    I'd like to know how he determined the axle was bent. If it was bent enough to be obvious you'd be having more problems than ball joints.
    As stated, get a second opinion, me thinks they saw you coming.
    2K XJ - 6" lift with 33s (No cutting) - See Full Specs
    1998 XJ Laredo stock
    XJ owners, visit us at www.soxja.org Southern Ontario XJ Association
    brownsville
    The mechanic who did the check over was a good friend and jeep owner for a long time, but I have gift dropped off in my laneway dana 44 waggy 3:55 welded diff front axle complete but just passenger drop hummmm
    Palmerston, On.
    Time Online: 6 Days 14 Hrs 36 Mins 10 Secs
    Avg. Time Online: 32 Secs
    I'm thinkin I have a d30 housing from an XJ sittin at the shop. Would you like me to take a look?
    Tim
    '98 XJ 2dr. 3" and 33" ATs --His--
    '99 XJ 4dr. 3" and 31 AT's --Hers--
    '72 J4000 --Ours?--
    It's all good.
Tags for this Thread
