Results 1 to 20 of 36
Thread: My 84 S10 on a Bronco Frame
    Lambton Shores
    Amazed
    Time Online: 4 Wks 20 Hrs 1 Min 20 Secs
    Avg. Time Online: 2 Mins 22 Secs
    My 86 S10 on a Blazer Frame
    Well might as well start this build thread even though its basically already built.
    It is a 86 S10 body on a Blazer Frame with a 350 v8 in her.
    The front axle is a D44 and the rear is a 14bolt.
    It has 38x16x16.5 Super Swampers
    Pipes out the hood.
    Bed mounted: Fuel Cell, Rad, Trans Cooler, Washer Fluid.
    Racing Seats, Full Roll Cage.
    Attached Thumbnails Attached Thumbnails PICT0119.JPG   PICT0122.JPG   PICT0127.JPG
    YouTube Videos
    98 AM General Hummer with 2" lift and 38" Tires
    1982 Suzuki LJ80V - Pretty much stock other than a light bar and some lights... lots of mods to come
    i did a blazer, but kept my frame, but i re used the radius arms.my tires dont stick out that far, oh and i drive mine daily. you still got the 3.50 gears?i do, and with the stock 4.3 it still goes pretty good. and f.i. is pretty sweet too.
    Lambton Shores
    Amazed
    Very nice, I am not too sure what kind of gears are in it I should inquire about that tommorrow. Also this rig has like no flex at all so I have to switch out the current leafs/shocks and get some new ones and mount the axles over the leafs. since this is all like body lift. More of a mud racer then a wheeler but still a fun toy.
    i ysed skyjacker cherokee 6" springs in my front, and stock s10 springs over the axle in the rear. but i have a totally different frame. mine flexes alright, but the locker makes up for less articulation
    Lambton Shores
    Amazed
    hah nice, Yeah mine is mostly body lift. it has spring over but the springs are stiff and almost straight across. so I definitely have to fix that.
    Lambton Shores
    Amazed
    so its been a looooong week trying to get this thing ready for the trails this weekend. most of it was chasing an oil pan that would fit on my "unknown" 350 chev engine but after sourcing one it appears it is from a 80-81 camaro.
    But yea who would have thunk it would take 3 days to change out an oil pan
    Also I added a new breather to it since the previous owner wasnt running one.
    I also did a tune up to it(new plugs, wires, dist cap and rotor) which went flawlessly.
    But yea heres some pics of the new items.
    I still got a couple more things to do to it before the weekend and that includes:
    bleed the brakes.
    grease it all up.
    get my tow bar tabs welded on.
    Attached Thumbnails Attached Thumbnails PICT0220 (Small).JPG   PICT0221 (Small).JPG   PICT0224 (Small).JPG   PICT0226 (Small).JPG
    not trying to be rude, but are you sure its a bronco frame? im pretty sure they were all coil spring front. and i suggest looking into getting some new front leaves. blocks on a front axle arent the best idea. just ideas. im not trying to point out fault. other than a little bit of surface rust. it looks good man.
    Lambton Shores
    Amazed
    Quote Originally Posted by buckinbullock View Post
    thanks and yea i am not too sure myself I am going by what I have been told any input would be greatly appreciated... I also heard front axle might be from a scout....
    Also the suspension was setup by previous owner I plan on getting some new leafs that will get rid of the 2" blocks and lift it 2-3" in the front to get some flex also plan to get some new ones for the rear as well and put the spring under the axle and lift her 3-5" to get some flex going. but that wont be till next year
    check out the steering, i think its a blazer frame. they are factory leaf front, and passengers side drop diff. they also dont have crossover steering. check out a fullsize chevy and see if the frontend looks the same. s10 bodies on blazer frames are kinda common-ish.
    Lambton Shores
    Amazed
    ok ill look into it. thanks for the tips
    stratford
    Time Online: 3 Wks 1 Day 8 Hrs 14 Mins 12 Secs
    thats Tony,s old truck ,at one time that was one of the fastest muddd racers around. it was set up with a real nasty big block,I hope u fix the steering from the firewall out it was pretty scary,that sure brings back alot of memories,where the hell did u get that
    Lambton Shores
    Amazed
    from nole here in london. If you know more info about it i would really appreciate it. at idle after the tune up she sounds nice but still not too perky from a stop need to fix the timing on it.
    Nice. Wear a helmet. Thats the kinda fun it's made for. Drive it like a rockstar.
    1991 Xj Gone to a new home.
    OF4WD #6069
    Lambton Shores
    Amazed
    So after i took the dist apart and spark plugs out found out that this thing was only runnin on 6 cylinders 2 of them had the plugs broken off at the dist... so lucky i did the tune up.
    Here is some video footage of it revving... I have some footage at night showing the flames but didnt pull it off the camcorder yet...
    http://www.youtube.com/watch?v=oA2ikGp0QwQ
    i watched the video. your neighbours must love you. sounded pretty good though.
    Lambton Shores
    Amazed
    heh yea i try not to run it too much but hard when its a new toy. I had to gun her for about 10 min and im sure they werent impressed then but hey it needed some carb cleaner heh!
    Dec 2006
    Hamilton(Waterdown)
    that thing looks fun fo rmud racing man!!! looks like it would do awesome in mud.
    hope ya have fun with it!
    london
    Time Online: 42 Mins 38 Secs
    nice buy. Did you happen to see his buddies truck around the corner?
    Time Online: 1 Day 11 Hrs 25 Mins 3 Secs
    I like the looks of this thing, it looks like it needs some work but definatley has potential!
    Lambton Shores
    Amazed
    Quote Originally Posted by b. View Post
    thanks and yea that thing is amazing... full size tractor tires, 5ton rockwells, divorce tcase for running a winch etc.
