Results 1 to 4 of 4
Thread: 88 xj front axle seal
    May 2008
    bowmanville
    Time Online: 2 Days 21 Hrs 24 Mins 37 Secs
    Avg. Time Online: 14 Secs
    i have a 88 cherokee limited 4x4 4.0 litre,i changed the right side u joint,since then the shaft has been leaking gear lube.wondering where the seal in the axle tube is ,if its outer by the wheel or inner,if its inner does the gears need to be removed.thanks
    Near London
    Time Online: 1 Day 7 Hrs 50 Mins 4 Secs
    The seal is unside the diff. did you search? probably should have done the seal when you did the ujoint. hope it helps.
    Bring back the Cherokee http://www.petitiononline.com/Cherokee/petition.html
    say what you want about my wife, leave my jeeps out of it.
    93 HO, 4.5" skyjacker lift, taurus fan, H4 lights, champion 8000lbs winch, custom home made front bumper, rear hitch, 136 amp alternator, 5-90's full mains set replacement with main fuse. High idle on switch, rear cargo area full extension drawer cabinet. Dual Batteries, Sanden oba and removable doors.V8 ZJ tie rod replacement with OTK insert.
    May 2005
    Up the Hill from "Shrek's Swamp" and down the road from "Cultural Hub of the universe"
    Time Online: 1 Wk 6 Days 9 Hrs 14 Mins 15 Secs
    Avg. Time Online: 1 Min 5 Secs
    86 CJ Juggy
    67 Chevy Step side
    79 C20
    May 2008
    bowmanville
    thanks toofargone very good link,thanks again
