Results 1 to 20 of 26
Thread: My new tire carrier!!
    Dec 2006
    Hamilton(Waterdown)
    Well finally put this on my rear bumper i made after getting the cash to buy the steel heres the pics!
    Coments???
    Cheers
    Feb 2005
    Bradford
    looks great man...most people are going to ask you what you used for the hinge and lock mechanisms.
    Dec 2006
    Hamilton(Waterdown)
    i got my buddy who is a tool and die apprentice to machinge a block of solid 1.5" down to fit inside a tube of seemless!
    somewhere
    Avg. Time Online: 15 Mins 1 Sec
    What size shaft did you use for the pivot? I used 1" on a friend's bumper and it ended up snapping due to lack of reinforcement. I rebuilt with the same size shaft but supported the shaft with a brace from the top.
    Dec 2006
    Hamilton(Waterdown)
    its 1.5" solid and that sounds like a good idead ill bend apeice of flat bar and weld it over the back!
    It isnt 100% complete i have a few triangle gussets to weld in here and there still
    Now i have a question for all of you! I picked up one of each type of latch i am not sure which one i shoudl use..
    So what one would you recomend??
    Pics!
    The one latch is a pin that slides as you flip the lever, the other is like a hand that grab's the other part and pull the 2 peices togethor
    Hamilton Ontario
    Time Online: 8 Mins 12 Secs
    I like the swing out dude! nice designe and looks great!
    92 Renegade
    Brrrrrrrrrrrrrrrrr!
    I have a Jeep too! wanna go out and play?!
    Aug 2007
    ElliotLake, Ontario home of the bugs
    Time Online: 1 Mth 1 Wk 6 Days 19 Hrs 52 Mins 46 Secs
    Avg. Time Online: 3 Mins 36 Secs
    #2 clamp style.
    my .02
    97 tj 4" lift rollin on 33"trXus m/t
    YOUR AN APPLE ( annoyingorange.com)
    "the purpose of life is to end" (agent smith)
    "to crush your enemies, see them driven before you and to hear the lamentation of their women" (Conan the barbarian)
    Dec 2006
    Hamilton(Waterdown)
    i was also thinking #2 haha
    West Montrose
    Time Online: 3 Wks 4 Days 23 Hrs 9 Mins 25 Secs
    Avg. Time Online: 2 Mins 8 Secs
    I like the latch, it's what I have on mine if you look at my profile page.
    82' CJ 7 with a few upgrades
    Tottenham
    Avg. Time Online: 5 Mins 14 Secs
    i have the last one on mine... and it works great...
    S.S.O.
    OF4WD
    Dec 2006
    Hamilton(Waterdown)
    well i used the last latch its all done other then some paint!! might add more litle things to it later but its good for now
    I know the latsh sticks out the back, but im not worried about it the tire sticks out WAY pas that haha there really was no other way of mountiing it to heve a forward pull on it... maybe ill get some 1/2" round stock and bend it in a U and weld it below to protect it from any tress that might jump out on the trail at me
    West Montrose
    Hey, It might be too late but there is a better way to mount your latch in the exact same location. I have the same one on mine and it doesn't stick out, it's flush once closed and it pulls the swing out taught...
    Look in my profile page on JK and look at "my albums & pictures" I have a close up pick of my latch there to give you an idea what I'm talking about.
    Dec 2006
    Hamilton(Waterdown)
    oh haha!! never even thought of doing it that way! good idea but ya its to late now... well its never too late i just dont feel like taking a zip disk to it jsut to move the latch... if i brake it off someday then ill re-install a new one same way yours is!
    thanks for the tips guys!
    Sep 2006
    Acton / Mississauga
    Time Online: 1 Mth 2 Wks 23 Hrs 37 Mins 32 Secs
    looks good, what material did you use? 2" x 1/8"? I would definatly put that hinge in a double shear setup. that seems to be the number one cause of failure
    Dec 2006
    Hamilton(Waterdown)
    2x2" by 3/16" what do you mean a double sheer setup?
    Time Online: 2 Wks 2 Days 5 Hrs 27 Mins 3 Secs
    double shear means 2 points of support on the pivot shaft. It splits the shear load on the shaft in 2, ie doubles the strength of your pivot. It's like you mentioned about welding on a gusset to support the top of the shaft (instead of the whole load bending the shaft where it's welded to the bumper)
    This is an example of a double shear pivot:
    Warn's gusset seems to be one of the better designs i've come across, but it's hard to get a good pic
    CRAIG-3D CAD junkie-IMAX Screen designer
    -97 ZJ #2 LTD...built,flogged & flopped all in a matter of 7 days..redefining luxury wheelin! 97 ZJ Laredo, hand built, abused, and jumped off a 12' snowbank... RIP
    Dec 2006
    Hamilton(Waterdown)
    i see i see! well unlike warn and probbaly some other company's i didnt just set a peice of round stock on my bumper and lay a bead around it, i cut a whole and sunk it down into the bottom of the bumper its welded on the top and bottom of bumper so i really can not see it going anywhere ill add a 3rd weld off the top just for added security though
    West Montrose
    Hey, Canadian ZJ! I'd like to support mine a little better. It is very heavy when the 2 fuel cans are full. Where can I get a pin like yours? I'd like to make mine into a double sheer like the one in the top pic. I noticed that the top of my tail gate isn't lining up with the tub as well as it used to when it's closed and the swing out droops a little when it's opened. My gate is attached to my swing out...
    Sep 2006
    Acton / Mississauga
    how is the first pic a double shear? that pin only holds the carrier open no? I dont see it, or is it a single and a double comparison?
    tuff- the problem isnt the shaft breaking off at the weld from not going through the bumper its from stress and fatigue on the shaft itself especially where its welded. All the ones Ive seen break are through the bumper and break where its welded(the weld weakens the shaft I guess) search pirate for swing out hinge or similar and youll see what I mean. it may not matter as much to you as you trailer it but for us DD guys the idea of the carrier breaking off on the highway isnt cool
    West Montrose
    It's like triangulation. When open, the hing has the pin to help bear some of the weight like a prop...
