Results 1 to 14 of 14
Thread: 89 yj frame repair
    Time Online: 3 Wks 1 Day 10 Hrs 5 Mins 17 Secs
    Unhappy 89 yj frame repair
    Well I noticed a little rust hole at the rear leaf spring area soo I did some investigation and this is what i found, More pics to follow as the build continues
    oshawa,ON
    Time Online: 3 Hrs 37 Mins 47 Secs
    I know EXACTLY what you mean.
    This is what I had to deal with.
    Time Online: 2 Hrs 55 Mins 54 Secs
    I had the same thing I found that if you use 6x3x188 square tube and cut the top off to the height of the fram rail it slides over perfectly.
    Time Online: 2 Days 1 Hr 17 Mins 59 Secs
    Avg. Time Online: 10 Secs
    I have fixed many like that. its a bitch but what can you do, its a jeep thing. if you want, I can give you a play by play on what to do.
    Steve Rogers
    Crazy Bastard
    frame repair plan
    Here is some pics of what I was thinking of doing to fix the problem just going to box it in using these. On a seperate note whats your opinion on Miller 135 welder just picked it up from work for 50 bones thought it was a good deal.
    newmarket
    Time Online: 7 Hrs 31 Mins 49 Secs
    hey what is the thickness in that steal? you should never weld a straight surface where you connect to the old frame think jigsaw puzzle its much stronger
    I wouldn't cap the old russty stuff. I would cut it out and make a new rear piece. as for the welder, it should be good for up to 1/8" material. Use gas as its much easier to weld upside down with.
    Apr 2003
    toronto
    Time Online: 5 Days 8 Hrs 33 Mins 32 Secs
    Avg. Time Online: 26 Secs
    Depending on the shackel you use, you might have a problem with the added width and depth of the frame rail. My lift shackels needed to be modified when I boxed in my frame. Not a big deal just added agro.
    that miller 135'll work great, but use the gas. it'll be worth it.and cut the old stuff out. it'll make it tougher to do, but you'll end up with better results.
    Thanks for the reply I am picking up the gas on Monday, Not sure if I have the nuts to cut out the old sh$t and weld in new, I just finished grinding all the rust off. Havent welded in a long time not sure if i'm up to the task. Would make a better job though.
    just go at it one side at a time. working opposite sides. (left side, right side, top, bottom.) i had to do framerails on my old malibu, sure its scary to cut up your truck, but when its all done, you can say you did it.
    your welcome to come out to my shop and i can give you a few tips on that repair i do them for a living. im in hamilton i live in burlington i could een come out to whwere your jeep is and show you around that welder .just email me for directions horses5.0@hotmail.com
    andy mud bros 4x4
    Aug 2007
    Stoney Creek, Ontaio
    Time Online: 1 Mth 5 Days 22 Hrs 12 Mins 21 Secs
    Avg. Time Online: 2 Mins 57 Secs
    frame repair
    mud bros.1 might be looking for someone to do a little repair on my frame, if your interested
    Ottawa
    Avg. Time Online: 3 Mins 9 Secs
    Trust me... mine was much worse... much worse. I got a new frame from Dynnommyte. You should just ask around for a new one.
