Thread: Cable activated Front axle Disconnect
    I'm looking to switch to this and want to know if anyone has a budget write up on this or know where I can find one. I am looking but have not found anything as of yet.
    Thanks In advance.
    Sudbury Ontario
    on the bottom of the forum page,theres the technical archives,in there there is a section on technical links,there is a link in there .
    Tottenham
    Avg. Time Online: 5 Mins 13 Secs
    I'm sure you can find one on here somewhere... I don't know if I have mine anymore... I'll have a look around and let you know
    just make sure you get good quality parts.... it took me a few months and many different levers and parts to make it work properly...
    S.S.O.
    OF4WD
    Nov 2003
    Welland
    Time Online: 1 Wk 3 Days 10 Hrs 33 Mins 37 Secs
    Avg. Time Online: 51 Secs
    I bought instruction on how to do it off ebay for like $6
    Gives full directions and a parts list to do it
    1987 Jeep YJ - Daily driver/trail rig - On the road but Currently under construction
    Thanks everyone for helping me realise I really do dislike people in general
    I'm just a regular Joe, with a regular Job, I'm your average white Suburbanite slob
    I like Football, and Porno, and Books about War
    ^^^ can you scan them and send me a file? that would be appreciated.
    Mar 2006
    Time Online: 3 Days 15 Hrs 24 Mins 27 Secs
    Avg. Time Online: 17 Secs
    '05 TJ, mall crawler
    '96 ZJ Limited, 5.2L
    '92 YJ, 4 Banger, 3.5" Lift on 33"s, Locked, Posi-Lok, Cobra CB --GONE :`(.
    "I'd try to see things from your point of view, but I can't fit my head that far up my ass."
    "When life gives you retards....hold a telethon"
    Mississauga
    The closer you get to a waterproof push/pull control cable, the easier it will be to make the whole thing work for you year-round. The single wire style throttle cable style used for things like lawn mowers and snow blowers is cheap and will work for a while, but is prone to seizing from rust. Bicycle brake cable is pull only, so your design should include a spring on the other end to pull it back.
    Princess Auto has some push/pull control cables in their hydraulic section that looked like a good deal - they have a knob & bulkhead connection at one end and a 1/4 " threaded shaft on the other (an overkill strength wise, but a lot cheaper than the thinner marine or truck/forklift style).
    When you add a heavy duty control cable to the cast aluminum shift fork, keep in mind that it was made for a light force ONLY for engagement (the vacuum motor doesn't apply much force, just a steady pressure until you started to move and the gears would line up and engage) & if you try to strong-arm it into place, it'll break. You can get a cast iron fork, but it still won't help it engage those straight cut gears - they have to line up.
