Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Project Winter Beater(95 ZJ Ltd)
  1. #21
    Time Online: 3 Wks 6 Days 4 Hrs 27 Mins 52 Secs
    Avg. Time Online: 2 Mins 13 Secs
    If it's high pinion it's a rev cut. NICE AXLE! Put stock ZJ shafts in it as they use a thicker U-joint and collar. They slide right in.
  2. #22
    Lambton Shores
    Time Online: 4 Wks 20 Hrs 7 Mins 19 Secs
    Avg. Time Online: 2 Mins 21 Secs
    thanks for info!
    Im not too sure what shafts are in it now but from what i am told and observed is the fork entrance on the axle that engages the double shaft section has been plated off.... so it is not hooked up at all but when I had her in 4lo and gunned it all 4 tires gripped so I am guessing it is a 1 piece shaft in there already or the engage mechanism is always engaged.
    But like i said i dont know too much yet so if anything doesnt make sense in the last paragraph then thats prolly why heh.
    YouTube Videos
    98 AM General Hummer with 2" lift and 38" Tires
    1982 Suzuki LJ80V - Pretty much stock other than a light bar and some lights... lots of mods to come
  3. #23
    Nov 2003
    Welland
    Time Online: 1 Wk 3 Days 10 Hrs 33 Mins 37 Secs
    Avg. Time Online: 51 Secs
    Quote Originally Posted by Injunfarian View Post
    thanks for info!
    If the fork has been plated off, then you probably already have the slightly stronger shafts in it now. From what I had found a few days ago on a different site, I believe the older Dana 30's can use the shafts from the newer TJ and ZJ Dana 30's which have better U-Joints
    1987 Jeep YJ - Daily driver/trail rig - On the road but Currently under construction
    Thanks everyone for helping me realise I really do dislike people in general
    I'm just a regular Joe, with a regular Job, I'm your average white Suburbanite slob
    I like Football, and Porno, and Books about War
  4. #24
    Lambton Shores
    Thanks for the info. I sure am learning alot with the project just like the last project, so that is always useful.
    Now for the updates:
    Brake lines are almost done just waiting on the flex line from rear axle to rear caliper to come in and that will be done...
    All four doors are now 100% working and no more squeeking...
    Front headlight is operational.
    she has a new valve gasket.
    new brushings for the sway bar links.
    did an oil lube and filter on her.
    new rotors in the front end.
    new battery.
    Plans for today is replace the inner grill/headlight housing since the current one is all cracked and broken and it wont pass safety without it.
    And replace the waterpump.
    Then she is off to the exhaust shop to button her all up and hopefully will be on the road some time next week.
  5. #25
    Lambton Shores
    Updates:
    Brakelines are 100% done and bleeded.
    Waterpump is installed.
    New driveside front caliper has been installed
    She now has her Y pipe fixed and a new exhaust from y pipe back with new O2 sensor.... but found a new problem.... exhaust manifold has a crack in it so gotta rip that out so Tommy's exhaust can weld it which also gives GREAT prices on exhaust work.
    Front Grill housing is taken off and half way done moving old items(headlight alignment gears, light housings, wires etc) to the new housing then should be installed tommorrow.
    Also question.... When truck is in gear and throttle is pumped i get a clunk then when i let off i get another clunk after opening up hood and holding brake and reving engine i noticed that the engine moves upwards alot(more than normal I believe)... Checked drivers side mount and looks good but notice there is like a bushing or something... do these normally fail or loosen? any idea/tips on how to fix?
  6. #26
    Caledonia
    hey i was just wondering about ur trailer it doesnt look like it has any suspension?
    is it a rough ride loaded or empty?
    i know its off topic but just thought id ask cause i wanna get one and wondering if its better to have one the does or doesnt have suspension.
  7. #27
    Probably Rubber Ride Torsion Tube Axles.
  8. #28
    Lambton Shores
    Quote Originally Posted by knucklehead View Post
    hey sorry about delayed response, it does have some small leafs on the trailer not too sure what kind but i can take pictures if you would like
  9. #29
    Owen Sound
    Time Online: 18 Hrs 8 Mins 22 Secs
    Motor mounts. Cheap and easy fix. Also a common failure for older ZJ 4.0's
