Results 1 to 3 of 3
Thread: 90 xj
    May 2004
    Calgary
    90 xj
    hey guys its been a while! me and my roomate are taking his 90 xj replacing the motor he blew with a 90 mj motor that has a factory rebuild and bore 40 over we are replacing head, intake and cpu with h.o from a 95 and than building the bottom end with after market components is there anything im missing from the h.o? and what kind of issues will we encure? i hope some one has done this before.
    If you've gottem smokem!!
    89 Waggy 5.5 rubi express 32's
    May 2004
    Calgary
    a couple pics
    Courtice, ON
    if your keeping the original wiring, will you be able to use the HO intake manifold? you may run into a problem with the throttle body having different connections. The Renix (early years) are 3 bolt and the sensors mount differently than the 4 bolt HO throttle body.
    If you have already figured this out, and your already doing this much work, why not grab a 99 intake manifold for another upgrade. check it out http://www.go.jeep-xj.info/HowtoIntakeManifold1.htm
    insert something witty here
