Results 1 to 20 of 24
Thread: Manual Posi-lock.
    Manual Posi-lock.
    I have had it with the vacuum motor....
    Here is the mod I did today. its a step toward the posi lock cable. But no time to finish it all today.
    Attached Thumbnails Attached Thumbnails Picture 004 (Medium).jpg   Picture 007 (Medium).jpg   Picture 008 (Medium).jpg   Picture 010 (Medium).jpg
    Waterloo / Ottawa
    Time Online: 22 Hrs 24 Mins 38 Secs
    What are you using, did you get a posi-lok kit or is it a home grown job? I was thinking of heading over to Princess Auto and getting a 10' control cable and 1" spring and giving it a go. I am interested in how this works out, can you toss in a detailed write up with pictures when it is done.
    Rod
    ___________
    -94 Camry - blown tie rod retired
    -89 Black YJ 4.2L, 92 axles with 4.10 gears, shogun racing seats, 33x10.5 BFG MT, 4" Rough Country Lift, bed lined tub
    -98 4Runner 210K on it now
    this is homegrown.
    I can post a full write up once I get the cable in. with more pictures
    I removed the vacuum motor and drilled and tapped a hole in the shaft (1/4 20NC). The bracket is made of stainless 1/8" plate. cut it to size drilled some holes and fitted it. I then just threaded in a piece of ready rod into the tapped hole put on a couple of nuts with washers.
    I can currently select by adjusting the two to move the shaft in either direction then lock them into place.
    Its a interm solution that should do the trick.
    Waterloo / Ottawa
    Great, let me know.
    Even if I end up working it like hubs for now that is not that big of a deal.
    I would love to see pics though, that is a big help.
    Good luck with it.
    I used a HD bike cable and a spring on my old Xj. Take the diaphram apart and cut the membrain out. Put sping behind on the shaft to hold it IN 4x4. Drill a small hole to feed cable through by the shaft. Drill hole in outer plastic case to insert the bike cable casing stop. Assemble, and use epoxy to help seal/ hold. Route the cable to cab, and mount bike brake lever on a sawed off handle bar. When the lever is pulled, with tensien of the spring being held, the fork is holding disingauged. Drill a hole in the lever for a pin to hold it there. To engadge, pull lever, pull pin. Can be used while wheelin' by just sqweezin the lever to do tight turns, or when 2-low is needed. The spring action holds it in 4x4, so if anything in the cable/lever mech. ever breaks, it will stay in 4x4.
    It cost me 11 bucks for the Heavy duty, Stainless, Shimano MTN bike cable. The rest of the stuff I found behind the bike shop in the garbage except for the spring, and epoxy.
    Took one night. Drill and a screw driver. Not as strong as the Store bought cable thing, but it never broke on me, or let me down.
    1991 Xj Gone to a new home.
    OF4WD #6069
    Time Online: 2 Wks 3 Days 5 Hrs 11 Mins 1 Sec
    jakflash, do u work at Wescast??????
    btw that home grown posi lock is lookin good, i had the real one that i bought off a member here, they work great
    but urs should do the trick just fine
    No fingers, no toes, she doesn't own elbows,
    No phalanges no knobby knees to knock.
    She don't need knuckles or hands to go see punk rock bands, She's always in the stands, she's nubs
    Quote Originally Posted by Dunham View Post
    Yes, Why do you ask?
    thanks... When I'm done it should be trick. the cable going in is a push pull cable so no need for springs. etc. Just need the time to finish the cable routing and mount. hopefully soon.
    Feb 2006
    caledonia
    Don't F that thing up brother....
    ^^^ who me?
    Not anytime soon. anyway.
    i see ur jeep there a lot, i work parttime for enterprise and always bring cars to u guys
    and i thought it was you from ur sig!!!
    u have a nice lookin yj
    ^^^ thanks... we should get meet sometimes. coffee or what not.
    I like the non-spring method, and the stoutness. What are you gonna use as a cable? First, cheap thing that comes to my mind is a E-brake cable.
    ^^^ I have already picked up a Push/Pull cable from PA. I need to route it and mount it. when I do so I will take several pictures and post them with a write-up.
    the whole job will cost me less than 50$ that is with a 35$ cable.
    sure man, you going to the rubicon grill this saturday??
    im heading up with a buddy and my girlfriend....
    Waterloo ont.
    Avg. Time Online: 18 Secs
    I have used a PTO cable a few times work great
    As much as I would love to.... I have other plans this weekend. but we could meet up for a coffee at timmies next week sometime.
    ooops
    paris ontario
    Time Online: 5 Days 8 Hrs 27 Mins 17 Secs
    Avg. Time Online: 26 Secs
    hows it comming!? would love that write up with pics when your done woot! also a question so it simply disengage the 4x4 you would just push the cable back in and it would disengage the front axle?
    Usually, DIY conversions are done with a spring. When you push the lever back down, a spring pushes the fork & collar back to the "disengaged" position.
    I'm waiting for the write-up too. I'll be saving it for future references. Every one I found on Google was either a $200 Posi-Loc kit install, or a dead link.
    Cheerful
    OF4WD 5435
    2dr - 2010 - Rubicon
    Cake bakers united
