Results 1 to 20 of 22
Thread: My TJ build up
    Time Online: 3 Hrs 30 Mins 45 Secs
    My TJ build up
    Here the latest update!!
    I'm running 38.5x15 Bogger
    Jan 2004
    Thornhill / Bowmanville, On
    Avg. Time Online: 54 Secs
    any pics to show it on the trail to see how your suspension works?
    Nov 2002
    Keswick
    Time Online: 6 Hrs 19 Mins 28 Secs
    joints on a 44 are no better than a 30
    sure,
    but i was always breaking my gear.. pignon.. cross pin.. etc.
    that should stop.. especially with the detroit locker..
    i did want to get wider too, my previous setup was with 38.5x11 Bogger and i did fall on the side..
    and here what i did on my axel to make it stronger
    Rotating the axle tubes to lift the pinion angle
    Reinforcing his welds with an axle truss
    Diff armor
    ChroMo 4340 axle shafts
    All new ball joints
    Crossover steering
    The tie rod is reinforced with square tube
    4.88 gears
    Detroit locker
    Warn premium hubs
    Ford Brakes
    Rubicon Express weld on kit
    WMS is 68"
    when i get some more money, i was thinking to put some CTM U-Joint coz i dont want to bust the axel shaft
    Mar 2003
    London, on. ca
    Time Online: 2 Days 44 Mins 56 Secs
    Avg. Time Online: 10 Secs
    putting in CTM's will guarantee that you break the shafts first. be aware of what your weak points are. if you use CTM's carry spare caps and shafts cause that joint won't give at all.
    i think the hub will fail before the shaft and the joint
    was thinking about using the fuse for the warn hub, just need to check if its good or not
    but i'll see how everything work with the spicer ujoint
    pinion angle
    not realy good to raise the pinion anything more than 10 deg can starve the pinnion berings of oil. if you mean you cut the center cection out of the front and roatated the tubes to raise the front without moving the alingment good stuff just keep it under 10 deg .
    exactly what i did.. for like 8 deg
    Jan 2006
    Pembroke ON
    Time Online: 1 Wk 2 Days 10 Hrs 16 Mins 14 Secs
    Avg. Time Online: 46 Secs
    hey hows it going? I don't know if you remember but I met you up at the auto club (and you also dragged my jeep off the road for me when my transmission and tcase took a dump all over the road).
    Jeep is looking good
    Here the test drive
    Hey! I remember you! i hope your jeep is doing better !!
    Ottawa
    Avg. Time Online: 3 Mins 9 Secs
    your tires look really thin in comparison to the height of them, i was going to ask if there is a purpose or reason for that.
    well, its 38.5x15
    go check on jax.monchar.com
    you will see the difference with the 38.5x11..
    Toxic River?
    Time Online: 4 Mths 2 Wks 1 Day 2 Hrs 1 Min 11 Secs
    Why didn't you just go with a 1 ton axle swap?
    Your using a 3" body lift, What are you using for a suspension lift?
    Here an update
    Trail Rig : 1ton TJ on 42
    Avg. Time Online: 28 Secs
    did you get dinged for the tires ticking out or were you just tired of the jeep always being extra dirty haha i like the build, theres alot of people just dumping on your shit but i like it. its an optimum setup for a tj give er take a few mods, minus the bodylift that is but who cares. looks good!
    personally, i likes the skinnyer boggers better, it gives it just a uniqe badass look.
    cheers
    love my 2.5
    thank you!
    yes... i had trouble with the cops about the tires...
    so now that should be alright
    Quote Originally Posted by WuMark View Post
    x2. Lots of bolt-on bandits with negative comments. Looks good buddy. See ya on the trail. Oh ya, loose the body lift. LOL
    May 2008
    Tillsonburg
    Time Online: 4 Mths 4 Days 17 Hrs 13 Mins 46 Secs
    Avg. Time Online: 10 Mins 15 Secs
    Looks good, how did you make out installing your fenders?
    OF4WD #5678
    Tri-city jeep club
    2005 LJ Rubicon
    2008 WK CRD
    2010 Ram 6.7 Cummins
    toronto
    Time Online: 1 Day 21 Hrs 24 Mins 32 Secs
    Avg. Time Online: 9 Secs
    Looks nice Alex great job. This guy wheels his shit like it's no ones business and hes a great guy too serving in our military. Cheers to you man
    GO HARD OR GO HOME !!!!!!!!
    Toxic River?
    Quote Originally Posted by 1sweetyj View Post
    LMAO....
