Results 1 to 12 of 12
Thread: HELP!! something broke on my jeep i do not know what it is!!
    Osgoode
    Time Online: 6 Days 4 Hrs 34 Mins 42 Secs
    Avg. Time Online: 30 Secs
    i was recently washing all the mud off my jeep when i realized somehting was not in the right place the drive had not changed but it definatly should not look like that
    __0_0_0_0
    [l_,[____],
    l---L -OlllllllO-
    ()_) ()_)---)_)
    my jeep eats what your hybrid saves!!
    Aurora
    Mellow
    Time Online: 1 Mth 1 Day 7 Hrs 49 Mins 29 Secs
    Avg. Time Online: 2 Mins 35 Secs
    you broke the sway bar connection.... just upgrade to sway bar disconnects and done...
    Colin
    I personally like the bds sway bar disconnects.
    Avg. Time Online: 11 Mins 8 Secs
    Dat rite there is yer sway bar link, on upgraded and modifyed trucks they install quick disconnect styles to allow for more articulation (flex) offroad. It is recommended when you replace one side to replace the other as well.
    Osgoode
    what are saw bar disconnects
    Wahnapitae, On
    Just go to your local auto parts store and tell them that you need 2 front sway bar links for your jeep.
    That would not help get disco's
    Google them and do some reading cas11, they are a good thing
    Time Online: 6 Days 6 Hrs 39 Mins 4 Secs
    To help explain it further its called an anti-sway bar. Stock they are not disconnectable unless you pull out a tool and remove it. Its meant to keep the jeep from excessive swaying\tilting\body roll when taking a tight corner but it limits the wheels travel up and down as both sides of the axle are connected to the same bar. So aftermarket option is to buy a sway bar disconnect which easily lets you disconnect or connect it depending on where you are driving. I also have BDS disconnect sway bars bought from Rockspyder (above sponser).
    2013 JK Wrangler
    2003 TJ Rubicon [SOLD]
    2002 KJ Sport [RIP]
    OF4WD #5542
    Oct 2005
    Norval
    Time Online: 6 Days 14 Hrs 27 Mins 54 Secs
    Avg. Time Online: 32 Secs
    I went through two endlinks before giving up and buying some JKS Quick Disconnects. They are a bit expensive but they give you more flex when wheeling. Stops that neck pain at the end of the trail too.
    Shelburne
    Cheerful
    Time Online: 1 Wk 5 Days 8 Hrs 5 Mins 13 Secs
    Avg. Time Online: 1 Min 1 Sec
    Hey looks like you and I did the same thing. You didn't happen to hit a large rock like me did you? I highly recommend the disconnects as everyone else is suggesting, unless this is simply a daily driver and you don't intend on wheeling it.
    98 TJ Sahara, 4.0L, 5 speed, custom bumper, Titan 12k, Front ACOS, RE 3.5" Superflex lift w/ Bilstein's, AA SYE, XJ CV Shaft, 33" Trxus, 1.25 JKS" BL, 1" Currie MML, (HC T/C skid plate to come).
    Disconnects are cheaper than replacing both links anyway.... I had the Rubicon Express Gen 2's, and they were easy to install and worked great...
    Get them even if you don't plan to wheel it -- the difference in articulation and even COMFORT when driving off road (even in mild conditions!) is worth it, your ass will thank you.
    Justin
    2012 Subaru WRX STi
    1996 Dodge RAM 1500
    Osgoode
    yeah i dont know when i did it i do alot of off roading in the petawawa area there is not to much rock up there
    Ajax Ont
