Thread: Brake Pad Wear (measurement)
    Mar 2005
    Georgetown, On-Freakin'-tario
    Time Online: 3 Hrs 1 Min 43 Secs
    Can someone please explain what it means when you see
    "BRAKES FRONT 6/32 REAR 4/32" ??
    What exactly does this mean? I sense that it isn't really a direct measurement at all. Do new pads start out at 32/32?? or 0/32?
    Seems like a bizarre measurement.
    Chris
    Chris
    Black '04 Sahara 5-spd, D44 3.73
    4-wheel ExtremeStop discs, Line-Xed tub.
    Ham Call VE2CZ
    Time Online: 6 Mths 2 Wks 10 Hrs 23 Mins 48 Secs
    Avg. Time Online: 15 Mins 57 Secs
    I'll go out on a limb and say that would be a direct measure of how much material is left on them
    New pads would be 32/32 if they had an inch of material
    0/32 would be steel on steel
    just change em when you hear metal on metal. If measurements and math can't be figured out by the time you learn how to drive maybe the short bus is a better option.
    Mar 2005
    Quote Originally Posted by Reverage View Post
    Don't think so, cause my numbers are going UP, not down! I was 6/32 last year, then I went to 7/32 and now I'm 8/32. Exactly how do they do this in the shop??
    Moonstone
    Avg. Time Online: 5 Mins 4 Secs
    If this is in a shop, I would imaging that they measure wear based on the standard width of your brake pads and then input how much is missing (worn).
    So wear would start at 0 and go to whatever the width is (probably something like 16/32 or so)
    So your brake pads would be at half life with 8/32 wear.
    -Red Green
    Schomberg
    ask them for how many millimetres are left and tell the to get in the now... pads are done at the 3-4 mm mark. i got mine back form the dealer once with 2mm of pad left after a "peice of mind" check up HA... the squeeling drove me batty
    WHEN IN DOUBT... GO FULL OUT!
    PB4L
