Results 1 to 11 of 11
Thread: TJ caster camber Problem
    toronto
    Time Online: 1 Day 21 Hrs 24 Mins 32 Secs
    Avg. Time Online: 9 Secs
    Hey guys I have a 97 Tj dana 30 on my rig and the front tires are leaning in on the top, is there any way to adjust this or is there an underlying problem that i am not aware of. I am about to take it for an alignment but dont want to waste the trip? Anyone have this problem before? I have an 8 inch double flex skyjacker kit on it if that helps. Also I have a 93' on one side between centre of axles and 92 on the other side, is that a control arm adjustment?
    Thanx
    Dave
    GO HARD OR GO HOME !!!!!!!!
    Time Online: 6 Mths 2 Wks 10 Hrs 23 Mins 48 Secs
    Avg. Time Online: 15 Mins 57 Secs
    8 inches of lift :confused:
    I would get things squared up with 92/93 thing and go from there
    toronto
    I just dont know if I should adjust the lower only or both upper and lower control arms
    Whatever it takes to keep your caster at I believe around 6 degree's (might want ot check that for sure)
    Bent housing, bad bearings or bad ball joints could be the culprit for the Camber
    toronto
    Thanx man my caster is fine but its the camber that needs attention thanx for the diagram and the info
    May 2008
    Kitchener
    Time Online: 1 Wk 22 Hrs 57 Mins 22 Secs
    Avg. Time Online: 39 Secs
    How about Hubs , ?????? Mine was doing that to and it was a hub problem !!!
    8 inches on a Dana 30? What size tires are you running? I would assume with that much lift you are running some pretty big rubber. That size of rubber might live on the street on a D30 but once you start off road you are going to start wearing u-joints, and pretty much gaurentee you will replace the unit bearings at least once a year. That's alot of sideways lateral force on those tiny bearings.
    Justin
    2012 Subaru WRX STi
    1996 Dodge RAM 1500
    Mississauga
    Time Online: 7 Hrs 8 Mins 53 Secs
    Quote Originally Posted by grinthock View Post
    Good call. If the c-clips on the u's are comming undone and camber is off it maybe ball joints or hubs.
    toronto
    Thanx guys the only reason its on the 30/35 is because I cant find a 60 to match my rear 60 for under 1800 or something stupid like that, everyone wants to get rich here it seems
    but to each his own, I will wait till something comes along. I am running 35 inch procomp xmt's
    Scarborough
    Time Online: 3 Mths 2 Wks 3 Days 8 Hrs 29 Mins 57 Secs
    Avg. Time Online: 8 Mins 48 Secs
    Hey there,
    I know this is an old thread but i wanted some consensus... i have noticeably negative camber up front (top of the wheels point inwards), and i think it's the ball joints as when i jack up the axle, once the tire gets off the ground, it pop's back to a neutral camber position (or at least visibly so). Am i correct is assuming it's the ball joints then? how would i test this? Jack it up and use a pry-bar?
    thanks
    m
    OF4WD # 6856
    97 TJ - 101" wb, Clayton triangulated long arm, Bilstein's, Dana 44/hp30 locked w/ chromo's, 4.88's, 4:1 TC, PSC/Currie, 37" Toyo's, rollcage...
    2010 ES 350
    2004 GMC Astro AWD cargo van - 2" lift with 31's
