Hi Guys,
Does anyone know how to disable the passlock system on a 2000 Jimmy? I have disconnected the battery and now when I go to start it, it will run for a second and shut off. Any help is appreciated.
Thanks in advance
Graham
Hi Guys,
Thanks in advance
Graham
87 XJ Best $400 I ever spent
88 XJ RIP
92 XJ MIA
95 XJ Former daily driver. Took my $
95 XJ Needed a lot of $$ so I got rid of it
96 ZJ Limited
96 ZJ Limited with Upcountry
98 ZJ THE 5.9 Gets better MPG than a Semi...almost
what caused the trip of the passlock? It is reset by leaving the key in the on position for about 10-15 mins, are you sure its the passlock feature on the vehicle that is causing the malunction. (crank - no start, with security light flashing, will start after 10-15 minute time out... intermitant... key and/or remote)...disconnecting the battery should not trip the passlock anti-theft..
Chad
OF4WD Member #6394
http://www.bayareawheelers.ca
will most likly need to be reprogrammed
rockin the 95 xj custom 4inch lift and 285/75/16 bfg mud terrain km2 and bds discosR.I.P
I had the battery disconnected to change the blend door motor on the heater box. After connecting it all up again all I get is a start for about 2 seconds then off. The battery wsa disconnected for 4-5 hours I would say. Is there any way of reprogramming it on my own or do I have to get the dealership to do it?
could also be a fault in the ignition cylinder, gm has a known issue with ignition system failures whether remote start installed or not where tumblers get worn down over time and send false reading to bcm, either replace igniton assembly and relearn new code to bcm or, when truck will start without light coming on, set parking brake put truck in reverse (engine off),There are 3 Passlock wires from the key cylinder to the Body Control Module; orange/black ground reference, red/white 12 volt reference, and yellow resistance code signal (these colors are for GM trucks only). cut yellow wire and place meter positive on key side of yellow wire&ground lead to orange black, turn key to crank position and hold to get resistance read, place a resistor of that same value between org/black wire and body side of yellow wire, tape up &leave keyside of yellow wire unconnected now truck will always see the code from resistor you installed so the accuracy of r-value is important be as close as possible
Chad
try the reset of 10-15mins with key in run position...see if that works for ya...
Thanks for all your help. I will try the reset again and see if I have any luck if not its step two with the resistor. Thanks again!!
Way back when I was working at GM, this would happen on battery changes every now and again. The computer would loose the code for some unknown reason.
Put a battery charger on it, and turn the key to run (do not attempt to start). Leave for 30 mins, and then start the truck.
'91 Frankenheep Edition. 4.0, 4" BDS, Richmond 8.8, 35" KM2's, Titan 12k, Mudsir Modded
The Drive Clean FAQ.
The 30 min learn is what noltz is referring to
Attempt to crank then leave on for ten - off for two - on for ten -off for two - on for ten then when the indicator goes out the last time crank the engine.
S.S.O., OF4WD
MY WHEELER THE SILVERFISH W.J.
^^ c.c. gotz the answer, make sure the battery voltage doesn't drop below 10.5 either or you'll never get the relearn to work
With my car, the ignition only needed to be switched off for 10 seconds in between start attempts
hero - the most overused english word
00 Silverado Ext LT Z71 S O L D
07 Kawi BF750I, cammed, muzzyed, outlawed, & copperheaded.
