Results 1 to 12 of 12
Thread: transfer Case for TH200-R4?
    Goofy
    Time Online: 4 Days 10 Hrs 21 Mins 45 Secs
    Avg. Time Online: 21 Secs
    Helo guys i purchased engine/transmission combo some time ago from a very dishonest member. I went for sbc 350 and TH400. It turned out that the engine was a sbc 305 and the transmission was TH200-4R. I've been doing some research but i can find any instance where The Th200-4r was used for 4x4. Anyone know any Transfer case can be bolted on this tranny. Thanks very much. and also wanted to know if anyone has Th400 laying around cheap? thanks very much.
    I got a TH400 from 2wd kickin in my shop. Not to sure on the condition of the internals but it is far from toast so I've been told. I going for a 4l60/700r
    Goofy
    TH400 2wd wouldn't work on Advance Adapters TH400 --> NP231 right? Thanks in advance.
    alot of s10's had 200r4's in em, especially with the 2.8 engine. you should be able to find a transfer case there. but im pretty sure most were np 207's. only the later years had the 231's. for the work required, you should just try and find a s10 with the 4.3 engine. they have 700 r4 trannys, and np 231's. and the 700'll bolt right up to your 305.
    Goofy
    well look at that....thanks thats some good information. do you know if there is an adapter between them? thanks. but you already made my day.
    My th400 just requires a tailshaft swap with part available from pretty much anywhere and your good to go.
    i don't know for sure. just go to a wreckers and look at s-10's. but i'd get a trans and case out of a 4.3 truck if it was me. you can but rotted trucks for like 300, and you get a stronger trans, with a lower 1-st gear, and a 231 is stronger than a 207.
    Goofy
    buckinbullok, i found i few s10's on google that use th200-4r but they 2wd , i guess there are no 4x4 for the 200-4r apparently the tailshaft is not removable or some C&*(% like that.
    Goofy
    hey JKMOTORSPORTS, can you hook me up with your TH400?
    my truck had a 2.8, 200r4 and a 207 case. but its a 85. too bad i thought it was all junk and scrapped it when i installed the 4.3.
    there were no 200 r-4's bolted to 4.3's 4x4's
    Keswick, On
    Time Online: 3 Days 6 Hrs 55 Secs
    Avg. Time Online: 16 Secs
    pm sent
