Thread: Transmission Rebuild
    Waterloo ON
    Time Online: 1 Wk 1 Day 4 Hrs 1 Min 4 Secs
    Avg. Time Online: 40 Secs
    Has anyone out there rebuilt their automatic tranny? Mine is getting to the point of death, so i'm planning on rebuilding a spare that I have. I would also like to build it a bit stronger.
    Just looking for some tips or advice if anyone else has done it before. Its the Torqueflite 999 that came behind the 4.2.
    Cambridge
    Time Online: 2 Hrs 3 Mins 31 Secs
    I have had some apart. The time you spend money on a re-beld kit you can get a used one cheaper. good luck man
    i would give it a try just be realy religious about your work space.
    rwd trans arent realy hard to build it just takes a few special tools.
    if walk in to a trans shop in the hood and explane what your doing a good shop owner would give you a few minutes of his day to let you know what kind of tools will be required for the 999.
    Waterloo ont.
    Avg. Time Online: 18 Secs
    yup done several, buy yourself an ATSG guide from Ideal or a place like that to match your trans, general rule of thumb never rebuid a trans with more than 300 000 km on it. over time the case actually grows and will not last long as a rebuild. the tolerances r key to success.wash parts as mutch as possible. and if trans worked when removed leave valve body alone.
    Waterloo ON
    Thanks for the tips, I'm not really rebuilding it because I'm being cheap, its just something that I would like to learn how to do.
    About leaving the valve body alone, is it hard to successfully install a shift kit?
    Waterloo ont.
    Quote Originally Posted by jboors View Post
    no most shift kits are easy to most replace the bearing check valves and replace a couple springs and usually a shim in the 1-2 shift valve its alway a good idea to have 600grit wetdry sand paper handy as the valves r steel contacting aluminium and once disturbed need a wet sand with trans fluid and the paper.any valve u disturb while doin the shift kit make sure u test in and out several times to be sure it does not stick.
