Results 1 to 14 of 14
Thread: Rotten unibody= Longarms
    North Bay
    Time Online: 6 Days 3 Mins 36 Secs
    Avg. Time Online: 29 Secs
    I'm sure some of you have seen my rotten unibody thread from a few weeks ago. So no need to repost those pics. I went ahead and patched/rebuilt the unibody. Well I went ahead and decided to go longarms because it was planned in the future anyway, this gave me a good excuse
    Here is a pic of the final reason I done longarms, after starting to patch this is what I found behind the upper mount!!!
    First are the parts from TMR. Awesome customer service and helped me with all my questions, shipping was super fast. Will deal with him again for sure!!!
    Quick pic after the patch job
    Working on the chassis mounts
    Axle upper mounts cut off, would have like to upgrade now but all funds went to the arms...
    The making of the truss
    Quick mock up to get measurements for upper link tabs
    With carefull measureing and centering, I was able to do the rest of the mock up for the upper links
    The making of the lowers
    North Bay
    Lower JJ end
    Uppers and Lowers tacked up
    Final mock up of the uppers
    Channels for unibody...
    Channel tacked on
    Extra bracing on my chassis mounts
    Tabs for extra bracing and skids on the lower axle end
    Brace all painted, starting brake lines
    Arms painted and assembled
    Test fit...
    North Bay
    Time for some longer springs and shocks
    View from underneath
    Tabs for brake lines
    Brake lines routed
    Had to get creative with the exhaust
    Had to go with flex, wanna make sure everthing will clear good before I go ahead and go with solid pipe
    Final assembly
    Everthing worked out awesome so far, done a bit of testing and flexing, and a few runs to make sure everthing worked properly.
    I also done a complete ABS delete while I was in there, went pretty easy, and upgraded front lines as well.
    Jeep is back on the road now because it is needed, and I am starting to put together my parts etc for the fronts, which will be a bit easier and I can do 90% of it out of the vehicle.
    Can notice the better ride already can't wait till the fronts are done, then all I have to do is decide on a spring and shock setup for a few added inches
    I have more pics and can answer any questions you have!!!
    I like the rap-a-round skids on the lower links. Thanks for the pics, and info.
    1991 Xj Gone to a new home.
    OF4WD #6069
    Near London
    Time Online: 1 Day 7 Hrs 50 Mins 4 Secs
    Looks great. Give more details on the ride. What is TMR?
    Bring back the Cherokee http://www.petitiononline.com/Cherokee/petition.html
    say what you want about my wife, leave my jeeps out of it.
    93 HO, 4.5" skyjacker lift, taurus fan, H4 lights, champion 8000lbs winch, custom home made front bumper, rear hitch, 136 amp alternator, 5-90's full mains set replacement with main fuse. High idle on switch, rear cargo area full extension drawer cabinet. Dual Batteries, Sanden oba and removable doors.V8 ZJ tie rod replacement with OTK insert.
    nice work, great thread!!
    North Bay
    Thanks guys.
    The rear is only done at the moment, the front will be done within the next month, but there was a noticble GOOD difference in ride with just the rears. A little rough but my shocks are too short so there is no sag. I tried some longer shocks the other day and HUGE difference but there toast, new ones are on the list of things to do. I was also a little currious about roll but it is same as the stock short arms and I'm not running a rear sway bar.
    TMR is TMR Customs in Newmarket. Tim is a AWESOME guy to deal with and the parts were perfect. www.tmrcustoms.com
    I will update when I start the fronts as well
    Near London
    keep us posted
    Newmarket, ON
    Avg. Time Online: 58 Secs
    looks really nice so far!
    what size square steel did you use for the truss?
    keep the pics coming!
    North Bay
    Front Long Arms
    Well after a while I finally managed to scrape up some time and finish my Long Arm set up on my ZJ. Here are the pics of the front set up.
    I'll let the pics tell most of the story..
    As before, starts with some steel and a pack of goodies from TMR!!!
    Cutting the mount ends for the cross member
    Making of the plates that bolt to the center section just like Claytons design
    Starting the center section
    Installed
    Elmvale, ON
    nice!
    Keepn' the Rubber Side down.
    I Support OF4WD
    thank you i needed a new sig
    North Bay
    Notching of one of the arms
    Bushing end
    Front radius arm before final mock up and cut
    Previous ride height
    Out with the old
    Some new shocks from Rockspyder
    Mock up
    Cycling the suspension
    North Bay
    Full Drop
    New ride height
    I still have a few details to work out and go on its maiden voyage. I will get some more pics when she's outa the garage
    North Bay
    Poser flex pics
    Went wheeling today, first time with the new suspension, worked great.
    Here are some poser shots of it
