Page 1 of 13 12345678910111213 LastLast
Results 1 to 20 of 256
Thread: Unlimited buildup
    May 2008
    Tillsonburg
    Time Online: 4 Mths 4 Days 16 Hrs 59 Mins 1 Sec
    Avg. Time Online: 10 Mins 17 Secs
    Unlimited buildup
    After selling my TJ I decieded to buy and build a rubicon. After many days of contemplating I chose an LJ rubi. The extra room and added wheelbase sold me. So my search began, after only finding 3 LJ rubicons with manual trans in ontario and two were yellow my choice ways easy seeing I did not want yellow again.
    My plans for the build up were clear after the learning curve of my TJ. As most builds go I can only do a little at a time as budget allows.
    The day I picked it up bone stock. And pics of old yellow
    Attached Thumbnails Attached Thumbnails JEEP RUBICON 001.jpg   JEEP RUBICON 002.jpg   JEEP PICS 010.jpg
    OF4WD #5678
    Tri-city jeep club
    2005 LJ Rubicon
    2008 WK CRD
    2010 Ram 6.7 Cummins
    May 2008
    Tillsonburg
    Theres nothing like bringing home a new jeep and stripping off all the garbage that should have never been there. First thing to go was the gay ss side steps, carpet, rear seat & seatbelts, hard top and bumpers.
    May 2008
    Tillsonburg
    Front bumper
    My plan was to build everthing possible for this project. I removed my superwinch epi9000 from my tj before it sold so my first project would be to fab up a new front bumper with a winch mount. I wanted a stinger style but nothing to extreme to look out of place on a stock jeep. Im not sure if my license plate is visable enough but am going to leave it till somthing is said.
    Attached Thumbnails Attached Thumbnails bumper shots 001.jpg   bumper shots 002.jpg   BUMPER 003.jpg
    oshawa
    nice so far keep em coming
    May 2008
    Tillsonburg
    Rear tube bumper
    Continuing with the tube bumpers this is what I came up with for the rear. It features a compact high clearence design with recovery points, trailer hitch and a wrap around tube to protect the larger than normal rear tub. Also had to trim the stock tail pipe which stock out like a donky dick.
    Next project sliders!
    Attached Thumbnails Attached Thumbnails tire 003.jpg   tire 002.jpg   tire 001.jpg   bumper 007.jpg   bumper 006.jpg
    north york.
    that is some awesome work dude. you deffinatly got some skills
    May 2008
    Tillsonburg
    Rock sliders
    My next project was rock sliders, The cost to by sliders for LJs are sky high and I was not happy with having some that were just like everyone else. Having access to laser cutting is one of the best fab tools I have and makes jobs like this easy. The plate is 3/16 with 1 5/8 tubing for the rails. I had the unlimited cut out because the factory sticker was covered up and tack welded a light ga piece of stainless behind for a custom look. Gave them a coat of bed liner and done. They came out better than expected and look great for fraction of the cost of odering from any supplier.
    My plan is to put 33" tires so that I can keep the factory 4.11 gears. Not sure what Im going to do to clear them at this time. I am considering a 4" lift or tube fenders in the front and opening the rear fender up and keep the suspension for a factory ride. Also plan to fab up some kind of tummy tucker skid plate to improve ground clearence.
    Attached Thumbnails Attached Thumbnails rock sliders 003.jpg   rock sliders 005.jpg   rock sliders 012.jpg   rock sliders 007.jpg
    May 2008
    Tillsonburg
    I picked up a used set of 33 x 12.5 x 15 MT baja claws with rims and thought these would be great for a bead lock project. Spent a couple hours on cad and came up with a design I was happy with, sent it over to the laser shop and had a set 4 cut from 1/4" mat. It took a few hours to clean up the wheels and weld on the rings. I gave the outer rings a coat of duplicolour wheel coating and started the install. I used 1 1/2 x 3/8 button head bolts with nylon lock nuts for my local fastenal. After about 1 1/2 hours a piece had them mounted up and ready to go. I also used 8oz of sand for balancing which i picked up at the local tire shop. Ive never lost a bead in my life but have not gone into singal digit pressures either. I hope the will make a good addition to my project. Now I just need to figure out how the fit 33"s on a stock jeep.
    Attached Thumbnails Attached Thumbnails bead locks 003.jpg   P1040224.JPG   P1040393.JPG   tire 005.jpg
    Smart build, and top notch fab.
    1991 Xj Gone to a new home.
    OF4WD #6069
    Ajax Ont
    Dude those are kick ass sliders
    if posible could you take a pick of the under part of the slider
    i would like to see how you tied it into the frame
    thanks
    May 2008
    Tillsonburg
    Soft top
    Sold the hard top for a good buck and replaced with mopar half top since no one makes an aftermarket soft top and this jeep will never see winter. This will be my spring and fall top and just a bikini for the summer.
    Attached Thumbnails Attached Thumbnails jeep pics 002.jpg   jeep pics 006.jpg   jeep pics 003.jpg
    May 2008
    Tillsonburg
    Found some info today about production numbers of the unlimited. In the 2 1/2 years of production there were only 27000 unlimiteds built total and only 12596 were unlimited rubicons. Im sure once you add my colour and manual trans to the list this jeep becomes pretty rare. Its almost a shame to cut it up now it may be a worth something down the road.
    Back to the build up I picked up some more goodies. Poison spyder crusher corners, Flowmaster super 44 offroad muffler, Mopar trail guide GPS. I have been shoping for a lift and seriously considering the new RC 4". If anyone has any info on this lift I would love to hear the reviews.
    Milton
    Time Online: 6 Days 9 Hrs 2 Mins 19 Secs
    Quote Originally Posted by Trail Head View Post
    I'm sure the plate is strong enough but will the tubes support the weight of the jeep from a high lift?
    Campbellville
    I have some very similar BDS rockers that will.
    May 2008
    Tillsonburg
    Ordered my lift shoud be in next week, Thanks sketchy rhino. Looking forward to ditching the stock suspenion. Will post up some pics before during and after.
    Fenwick
    Time Online: 23 Mins 20 Secs
    I was This Close to a TJ Unlimited before I bought my Pathfinder. I am going to have to settle for living vicariously through your build. Looks great! Keep us posted.
    May 2008
    Tillsonburg
    update
    Got my lift friday and I have to say I am impressed, RC has really steped up with there kits. Going to start the install sunday. Heres a few pics.
    Attached Thumbnails Attached Thumbnails Copy of P1040469.JPG   P1040516.jpg   P1040517.jpg
    May 2008
    Tillsonburg
    Lift install
    just finished up the lift install, every thing went pretty well with only a few issues. I am waiting on my shocks and have some clearence issues in the front end. My track bar is contacting my diff cover and drag link is contacting the swaybar bracket. I think I need to play with the links to rotate the axle for clearence and get it a little closer to spec before I take it in for an alignment. Overall Im very pleased with the out come and the jeep looks great and flexes well.
    Attached Thumbnails Attached Thumbnails P1040519.jpg   P1040518.jpg   P1040526.jpg   P1040525.jpg
    Time Online: 1 Mth 3 Wks 4 Days 20 Hrs 3 Mins 7 Secs
    Looks good Trevor! You dont waste any time .
    May 2008
    Tillsonburg
    Quote Originally Posted by gypsy-jeepster View Post
    Thanks, I dont have alot of time to waste on my own stuff. You should post up some pics of your new parts.
