Results 1 to 20 of 24
Thread: Jeep Bow-Tie Build up
    Deep River, Ontario
    Time Online: 1 Wk 1 Day 9 Hrs 47 Mins 54 Secs
    Avg. Time Online: 39 Secs
    Jeep Bow-Tie Build up up date!!!
    Here are some up to date pictures of my Build.
    still have a bit lift but hopefully I have it ready for the MUD with in a couple of weeks.
    1992 YJ Chevy 350
    700r4 trany, NP 241 T-Case
    2" Body lift
    Attached Thumbnails Attached Thumbnails Jeep Body Aug 27.08 .JPG   Jeep frame Aug 27.08.JPG   half done 3.jpg   half done 7.jpg   Jeep 011.jpg
    Courtice, ON
    Avg. Time Online: 1 Min 35 Secs
    thats gonna be a nice lookin rig in the end.
    Cheap River tho... come on, Chalks where its at if your in a River town!!!! My buddy lives in Deep, and I moved from Chalk last summer. Beautiful area out there.
    insert something witty here
    Time Online: 2 Wks 3 Days 5 Hrs 18 Mins 4 Secs
    tons o fun!!
    looks nice man
    No fingers, no toes, she doesn't own elbows,
    No phalanges no knobby knees to knock.
    She don't need knuckles or hands to go see punk rock bands, She's always in the stands, she's nubs
    Avg. Time Online: 3 Mins 29 Secs
    That looks great! I wish!
    If you have a stock rear axle I hope you have at least an 8.8 explorer axle waiting and ready to go in.
    Time Online: 1 Mth 2 Wks 6 Days 18 Hrs 52 Mins 39 Secs
    looks familiar, good job!
    You WILL have problems with that power steering pump set up. Mine was exactly the same. I just switched over to a serp belt and it is greatly improved.
    Deep River, Ontario
    What problems did you have with the power steering pump set up??
    the v belt would not take the load of the pump trying to turn the larger tires, so it would always squeal and constantly wear down.
    Also i spoke with dvsjeep and he said when i want to upgrade to a psc pump that it wouldn't make a difference with my current v belt set up.
    The pump is still working too hard so I will install hydro assist sometime in the next little while, but is way better with the new serp belt.
    Hope that helps.
    Oct 2005
    Vankoughnet
    Time Online: 9 Mths 1 Wk 1 Day 11 Hrs 27 Mins 28 Secs
    Avg. Time Online: 21 Mins 33 Secs
    Power steering and V-belts:
    Almost all v-belt engines will have the belt slip and squeal when at full lock ( Maximum Pressure). When you are running larger tires the load on your steering system is much greater and it requires more pressure more of the time, this causes the belt to slip more often. A slipping belt gets glazed and then slips more easily each time it happens. Most people try to fix this by tightening the belt more. This just puts extra side load on the power steering pump shaft wearing out the pump or breaking the shaft. Power steering pumps do not have bearings in them, only bushings and they are not designed for excessive side loading.
    A serpentine belt system has much more contact surface with the power steering pump pulley and will not slip as easily. They are normally self tentioning so you don't overload the pump shaft.
    A stock power steering pump can put out 2.5 gpm @1000 psi thats about 1.5 HP. A Hi-flow pump that would typically be used on a Steering assist or full hydro set up will put out 4.5 gpm @ 1600 psi, thats over 4 hp. With numbers like that you can start to see why your V-belt setup is not really up to the task.
    If you have to use the V-belt, get as much wrap on the pulley as possible to minimize slippage.
    ^ and that's what he told me..
    Hillsburgh
    Time Online: 5 Mths 3 Days 19 Hrs 6 Mins 53 Secs
    Avg. Time Online: 11 Mins 54 Secs
    He's so smart.... and it makes sense too!
    Jan 2003
    Paris
    Time Online: 1 Wk 3 Days 2 Hrs 32 Mins 25 Secs
    Avg. Time Online: 46 Secs
    Looks good, you will love the power upgrade...
    Just curious about the power steering problems, I have a stock Chevy v-belt setup with no problems of slippage turning a Dana 44 on 33's...
    What size tire/axle setup are you running?
    I've been running this setup for 5 years...
    MegaTherion
    '87 YJ - Chev 355, 700-r4, Dana 300, Dana 44s, 4:10s, 4" Super Lift, 35s.
    Deep River, Ontario
    Thankas guys, I'll have to look in too buying a serp system. Cheers
    Deep River, Ontario
    have you guys had any other problems I should know with this build. What about drive axles?? And I'm not sure if I want to run daul exhaust or single exhaust??
    I have run dual 2" and single 2.5" and the single does help the seat of the pants torque down low. The Single is also easier to route in a CJ but the YJ frame is wider and gives you more room for duals. If you are going to do a spring over you will need a traction bar and the single is not in the way then.
    Quote Originally Posted by MegaTherion View Post
    MegaTherion
    38.5 x 16" boggers 10 psi. on a 60. clearly need an upgrade.
    beamsville
    Avg. Time Online: 4 Mins 42 Secs
    Quote Originally Posted by bensjeep View Post
    also get a close ratio steering gear box 3-3 1/2 turns
    Deep River, Ontario
    Hey, does anyone have a engine wiring diagram for chevy 350??
    Deep River, Ontario
    Hey, do have a engine wiring diagram for chevy 350?? to a jeep harness??
    google it, there are tons out there. Thats where i got mine.
    Anything specific you need to know?
