Results 1 to 20 of 20
Thread: My Rebuilt Build Up
    Waterloo
    Time Online: 1 Wk 2 Days 5 Hrs 2 Mins 44 Secs
    Avg. Time Online: 45 Secs
    My Rebuilt Build Up
    This is my 96 chevy blazer. i built it last winter and tore it down and rebuilt and upgraded some things. here's some pictures of the progress:
    Doubler Box
    Motor Mounts
    Rebuilt and Tapped the Steering Box for Hydraulic Assist
    New Spring Plate With Mount for Hydraulic Ram
    Hydraulic System in the Works
    sweet good to see another blazer buildup in a sea of jeeps.
    is that a d300 with a 241 range box?
    here is my build thinking about some tcase upgrades myself.
    might go with a 203 range box with a ford 205 on the backhttp://www.jeepkings.ca/forums/showthread.php?t=81561
    Time Online: 1 Wk 2 Days 15 Hrs 20 Mins 41 Secs
    Avg. Time Online: 47 Secs
    Nice, that looks awsome. I shouldn't be far behind you guy's. I still have a few more parts to get but I am almost there. Soon I will be starting modding. Nothing is better then hearing the power of a chevy in the morning. GET-R-DONE.
    Ya info on the Tranny and T-cases. Did you buy or built the adaptors. I want to keep my D300 when I go to my SBC and a 203/205 is a huge tcase setup.
    Waterloo
    last season i ran the dana 300 behind my 4L60E tranny using a novak adapter. with a little modification, a np231 bolts right up to that same adapter. so i will be running a 231 based crawl box. my buddy and i made the adapter plate and clocking ring. i am waiting for a tool to arrive to cut the splines for the mid shaft and then she's ready to go in.
    i agree that a 203/205 setup is enormous. the dana 300 is a great case and its small size makes it easy to fit in the vehicle.
    Waterloo
    hey punisher, are you modifying an S10?
    Quote Originally Posted by 85 CJ7 4x4 View Post
    Actually I am modifying a 99 Sonoma, but basically it's the same as a S10.
    Waterloo
    i have a 2001 Sonoma with 6" Superlift and 31s. i will offer some advice. CUT OUT THE F$%KING INDEPENDENT SUSPENSION AS SOON AS POSSIBLE! take it from me, with larger than stock tires / offset wheels, she will become a dangerous money pit. i am changing unit bearings twice a year (at $300/unit) and the idler arm is worn out one day after i install a new one. aside from that, the steering sucks. it is sloppy, hard to turn, and the steering radius (which was never great) is shot as soon as the lift goes on. I am actually using my tow rig as my daily driver right now. not sure what your plans are for the little truck, but there's some advice. I have a HP Dana 44 and Ford 9" waiting to go into my Sonoma.
    So far I got a dana 44 for front and a ford 8.8 for the rear and a few other parts. I am hoping to run on 36" tires after all said and done. lol I already decide to remove all that ifs crap.
    i would like to know how responsive the PA hydraulic ram is? Is there any lag? that is quite a large bore cylinder.
    Waterloo
    Quote Originally Posted by Punisher View Post
    good call, just thought i'd make mention
    Waterloo
    Quote Originally Posted by Chevy YJ View Post
    the ram was $170.00 it is the canadian made one. the PA brand ones are like 5 inches longer overall for a cylinder with the same stroke. it is a 1.5" bore, so a pretty little guy, with 6 inches stroke. if you notice in the photo, i haven't even got the other end attached to the tie rod yet, so i don't know how responsive it is. i am anticipating it to be a little slow, but it seems like a lot of people run 2 inch bore rams, so we'll see. if it is slow, i will either make some mods to the pump, or else get the PSC high output pump. just got the engine running again tonight after doing all new seals and gaskets, found out that i have a leak i my box. it is the first steering box i have ever rebuilt, so it is bound to happen. i should be changing that seal tomorrow and getting that tie rod mounted, so i will let you guys know. here's a picture of the steering oil reservoir that i made to handle the additional fluid. My cooler should be in tomorrow.
    Waterloo
    Got my cutter and cut some splines for the mid shaft.
    Waterloo ON
    Time Online: 1 Wk 1 Day 4 Hrs 3 Mins 14 Secs
    Avg. Time Online: 40 Secs
    Looking Good!
    Waterloo / Ottawa
    Time Online: 22 Hrs 24 Mins 38 Secs
    Cannot wait to see what that thing will do this summer.
    Rod
    ___________
    -94 Camry - blown tie rod retired
    -89 Black YJ 4.2L, 92 axles with 4.10 gears, shogun racing seats, 33x10.5 BFG MT, 4" Rough Country Lift, bed lined tub
    -98 4Runner 210K on it now
    Waterloo
    Some more pictures. got the transfer cases in and it moves under its own power again! Also started messing around with building the triple stick shifters.
    Waterloo
    More photos of my progress
    Waterloo
    Waterloo ON
    Hey, you should put some new pictures up jake.
    oshawa
    hey punisher i think i see u all the time in oshawa im in the red xj with all the sticker on the rear window
