Thread: Dark Sludge in Rad Overflow Container
    Toxic River?
    Time Online: 4 Mths 2 Wks 1 Day 2 Hrs 1 Min 11 Secs
    Hi,
    I was just checking under the hood of my friends car (2001 Malibu) today and I noticed some darker coloured sludge in the rad overflow container...
    Any idea's what that could be from?
    check the oil dipstick and see if it looks like choco milk
    Dec 2003
    Peterborough, ON
    Time Online: 2 Mths 1 Wk 6 Days 23 Hrs 50 Mins 51 Secs
    Avg. Time Online: 6 Mins 5 Secs
    Did you buy the car used? Is there a chance someone in the past put a leak stop fluid in it in the past? (Bar's Leak Stop, etc.?) Those things will make it look like mud.
    But also check what Mayhem suggested as it is very likely to be the culprit as well.
    yeah, I'm thinking head gasket too.
    cayuga
    Time Online: 8 Hrs 58 Mins 51 Secs
    odds are it is the intake gaskets that are leaking or was in the past.those engines are bad 3.1L and all te chev v6.
    if it has never been done then do it before it takes the engine out.
    Toxic River?
    I thought it was the head gasket... but i checked the oil at the same time but no milkie mix... there is a aslight tick in the engine...
    Any way you look at it, there is something wrong enuff for him to let a mechanic take a boo at it, as much as we would all love to help online diagnosis is a bit of a bear with this kinda stuff.
    Get him to drive strait to a mech and have him check out the odd substance.
    ..and then let us know heh
    Toxic River?
    Quote Originally Posted by MayhemInc View Post
    LOL... he is actually getting posted and is leaving Thurs, im debating on buying it since he needs it gone. He actually got a mechanic to look at it, he was told that the head gasket was gone and that there was a need for connecting rod bearing maybe..... There is no outer leaks... Im not too sure how on the ball the mech was that he took it too...
    Dec 2003
    Peterborough, ON
    Quote Originally Posted by Impact View Post
    There's your oil sludge.
    There's your engine tick.
    Apr 2006
    Dresden Ontario
    I have an 02 Malibu. I can tell you with almost certainty that the tick is piston slap and VERY common on these vehicles. It is relatively harmless certainly not worth spending lots of money to fix.
    As for the sludge in the overflow these cars are also known for intake manifold gaskets going out.
    Unless the mechanic verified the head gasket leak with a compression test, exhaust leaking into the coolant (does it overheat) etc. I would not rule out the intake manifold. The sludge could be oil which could come from the head gasket but could just as likely come from the intake manifold gasket as well.
    There are service bulletins on both these problems.
    1985 CJ7 Aluminum tub, 31's
    1985 CJ7 All steel
