Thread: 97 gmc 4.3 no start?
    Sudbury Ontario
    Time Online: 6 Days 10 Hrs 20 Mins 29 Secs
    driving to work this morning,my baby just died and will not start .It has lots of fuel pressure at the shrader valve on the intake,the fuel pump is running ,nice blue spark from the plug wires,3/4 tank of gas ,350,000 km and running smooth ,cranks fine,.I cant scan it untill late wednesday night ,just wondering if anybody has any ideas .
    Oct 2005
    Vankoughnet
    Time Online: 9 Mths 1 Wk 1 Day 10 Hrs 18 Mins 48 Secs
    Avg. Time Online: 22 Mins 57 Secs
    Crank sensor, located under the crank pulley, check the plug and wires, there open to road grime and can get damaged.
    Cam positioning sensor located on the side of the distributer, remove the cap and check that the sensor is still in place., nope not that, you said it was running when it died, so not likely the cam sensor. It can run of the Crank if you loose the cam.
    Thats all I got for now
    Sudbury Ontario
    thanks,will check it tommorow .
    london ontario
    Time Online: 22 Hrs 26 Mins 20 Secs
    4.3's are usually cap/rotor issues,lol
    Richard
    13 JK Sahara Unlimited
    Sudbury Ontario
    new cap and rotor,wires and plugs a month ago,but I have awesome spark at the plugs
    the vortec motors love fuel pressure make sure you put a gage on it and you should have 60-65 lbs steady while cranking at wot.
    also dump a bit of fuel in the intake if it coughs its a week pump for sure (verry common with vortecs)
    belwood
    Time Online: 4 Hrs 26 Secs
    x2 what mudbros said, have seen vortecs before that seem to have good fuel pressure but won't run, needs enough pressure to overcome the poppets
    novar
    Time Online: 3 Hrs 35 Mins 14 Secs
    my 4.3 97 blazer did something similar there is a block of wires under a black cover on inside driver fender, $1.86 for a fusible link I was back on the road. worth a shot.
    Sudbury Ontario
    guess I should of posted back on this earlier ,long story short ,it had only 20 lbs. of fuel pressure once I finally found my guage .. I was told a little over $300.00 for a new sender ,so I searched on flea- bay and found a ton of pumps for about $25.00 u.s. ,and the sellers were good enough to include the proper part number in their adds ,so a quick trip to the local parts store with $80.00 ,and about twenty minutes taking the sender apart ,I was good to go .
