Thread: 95/96 Sunfire 2.2 the same?
    Near London
    anyone know if the 2.2l 4 cyl in a 96 Sunfire is the same as the 2.2l 4 cyl in a 95 Sunfire?
    Would the 95 be OBDI and the 96 OBDII? would it matter?
    need help asap, currently vehicleless
    the block and head should be the same.
    did you destroy the engine or does it just need the head rebuilt those cars are common for head gasket problems
    hamilton/flesherton
    Time Online: 3 Wks 1 Day 17 Hrs 34 Mins 40 Secs
    Avg. Time Online: 1 Min 51 Secs
    I had a 97 sunfire...as far as I was told they were the same from 95-99, could be wrong though
    young kid learnin the hard way
    90 YJ 4.2L, howell TBI, 4L head, 4"lift with 31x11.5s. broke it, welded it, broke around the welds, welded it again, sold it
    99 grand cherokee, 4.7L. 2" BB, 245/75R16
    Sudbury Ontario
    pretty sure that was a new engine design in 95,which if true would pretty much mean they are the same .As for obd1 or 2 ,if you have both engines complete,just swap out any sensors or whatever might be different,if anything at all .
    Jan 2006
    Time Online: 2 Wks 6 Days 23 Hrs 40 Mins 43 Secs
    Avg. Time Online: 1 Min 43 Secs
    '95 has no block sensors, '96 has cam sensor '97 has has crank and cam sensor,so..... if you have a '95 you can use any 2.2 up to 1997, if you have a '97 you have to use that year only
    W "GO PREPARED" W
    2014 Sahara Unlimited
    WARN winch equipped!
    Near London
    the head gastket went but there coolant in the oil,
    thank u kindly, thats the info i was looking for, i have a 96 engine going into a 95.
