Results 1 to 4 of 4
Thread: average winch depth
    Aug 2007
    Ingersoll ON
    average winch depth
    I'm going to be fabbing up a bumper this weekend, and was considering the possibility of mounting a winch down the road, any suggestions of how much room i should leave on the bumper to fit the winch in front of the rad??
    Jun 2003
    Welland
    Time Online: 1 Day 8 Hrs 12 Mins 58 Secs
    I did a quick Google for you and came up with this!
    Champion 8000lb winch
    Specifications
    * Rated Pull 8,000 lbs (3,629 kgs)
    * Gear Reduction Ratio 210:1 (DC 12V)
    * Motor Series Wound Motor
    * 3.6 HP / 2.7 KW (DC 12V)
    * Drum Size 2.48" (D) x 9" (L)
    * 63 mm (D) x 228 mm (L)
    * Cable 5/16" (D) x 95' (L)
    * 8 mm (D) x 29 m (L)
    * Overall Dimensions 22.05" (L) x 6.69" (W) x 10.63" (H)
    * 560 mm (L) x 170 mm (W) x 270 mm (H)
    * Weight 69.30 lbs (31.50 kgs)
    * Mounting Bolt Pattern 10" x 4.5"
    * 254 mm x 114.3 mm
    Warn M8000
    Winch Dimensions: 21.04" L. x 6.3" D. x 7.6" H.
    Mounting Bolt Pattern: 10.0" x 4.5"
    The Lost Soul R.I.P.!!!!
    Frogzilla
    87 Samurai LWB, 1.6L Injected, 38" TSL's, SPOA, Mighty Kong w/ Gorillas, Toyota axles front and rear, Toyota Hi Steer, and 6.4:1 Gears. Lincoln front and rear, 5.29 gears, Power Steering and frame stretch. Lets play guess the parts! 9500lb Champion front and 8000lb Champion rear, got to pull out the Heeps with something.
    http://community.webshots.com/user/xjrob
    www.so4x4.myfastforum.org
    lostsoul71@hotmail.com
    Sep 2002
    Time Online: 2 Wks 2 Days 11 Hrs 29 Mins 41 Secs
    Avg. Time Online: 1 Min 21 Secs
    7" from face of the Fairlead mount to the rear of the plate will allow for most model winches .
    Cheers
    Aug 2007
    Ingersoll ON
    thanks boys, huge help... bumpers away
