Results 1 to 18 of 18
Thread: 231-300 Doubler
    tecumseh Ontario
    Time Online: 8 Hrs 55 Mins 14 Secs
    231-300 Doubler
    Building doubler for 231-300 with shaft and clocking ring.
    No pic for clocking ring yet.
    Anyone interested in a doubler while i'm in the process, no price yet still gauging interest on this hotness everything included plate, shaft, clocking ring and bolts.
    Fergus
    Time Online: 1 Wk 4 Days 16 Hrs 54 Mins 20 Secs
    Avg. Time Online: 57 Secs
    would be intrested in a Chevy np231/Dana 300 kit.
    ~KAMIKAZE~
    A bunch of Flatties
    Near London
    droooooooooooooooooooooooooooool, now if only i had a running jeep to put this in
    My Box4Rocks is awsome! The control of 7.12:1 is fantastic. I can't say enough good about it. No leaks, no shifting problems, nothing to complain about at all.
    Good luck with the home made version, the spud shaft looks good as long as you get it heat treated.
    Waterloo ON
    Time Online: 1 Wk 1 Day 4 Hrs 3 Mins 14 Secs
    Avg. Time Online: 40 Secs
    Looking good, what kind of machinery are you working with?
    verry nice did you mill the spline or have it rolled?
    i would like to have some axleshafts splined for my ford front d44 but am a bit worryed about removing material
    How much? REALLY interested. Was going to make my own and weld my shaft as I don't have the ability to spline cut.
    Let me know if you want to make another or at least a shaft.
    Also what spline counts are is you shaft. Can't remeber if using a GM NP231 is different then a Jeep NP231.
    Waterloo ON
    I made one this year. I just turned down the original shaft and cut the splines. It hasn't been beaten on much yet, but has been working great.
    Really, could you do another? I have means of getting it heat treated.
    Collingwood
    Time Online: 3 Days 2 Hrs 11 Mins 59 Secs
    Avg. Time Online: 15 Secs
    is there room under a TJ for that?
    I don't care who ya are...that's funny!!
    Cheerful
    I would think you could jam that into a TJ.
    OF4WD 5435
    2dr - 2010 - Rubicon
    Cake bakers united
    tecumseh Ontario
    Thanks for the replies, I could do a chevy one but i would need s chevy case or the bolt pattern, the shaft is not complete yet just got it back this friday so monday its going for heat treat and grinding (oh its 4340 chromo and the splines are rolled). Small end spline count is 23 for the stock 300, but can make different ones if need be. We can check and see if it fits under a tj and get back to you. This plate is just a proto so disregard the chopped hole on the bottom right.
    I believe WuMark has one in his 4 banger TJ.
    plate for a Chevy case should be the same, but I'm only interested in a shaft.
    Mississauga
    Time Online: 7 Hrs 8 Mins 53 Secs
    Cooooooooool!
    03 TJ Rubi, 4" Super lift coils w/ RE adj. Superflex arms, Pro Comp front adj. track bar, RE rear adj. track bar, 1" BL, 1" MORE bomb proof motor mount lift, Poly tranny mount, AR Baja wheels, 35" BFG Krawlers, Staun internal bead locks, Tom Woods CV drive shaft, Warn M8000, locker safety over ride, Four Real steal front stinger, Bestop tire carrier, Smittybuilt rear bumper, 4 Hella 500 on a light bar. The last ones for the yee haw factor
    Avg. Time Online: 22 Mins 38 Secs
    Once it's all buttoned up you should make a few rings and shafts. Let me know how much. I'm in.
    Apr 2014
    United States
    Time Online: 37 Mins 2 Secs
    Bringing this back from the dead. I'm trying to make a shaft for a doubler. Now i know the 23 spline portion is a 30 degree pressure angle on the splines, but what about the 34 spline section that goes into the planetaries? is it a 45 degree pressure angle? Thanks for any help.
    Avg. Time Online: 10 Mins 4 Secs
    Old thread indeed....
    Check out this one.
    http://www.jeepkings.ca/forums/showt...ild&highlight=
