Thread: 1995 Camaro wont start
    Dec 2008
    Time Online: 2 Wks 6 Days 20 Hrs 16 Mins 41 Secs
    Avg. Time Online: 1 Min 43 Secs
    So my buddy just picked up a old camaro from this dad, we had the thing running for a week and then it just died. we figured okay battery, new battery later wasnt it. i dont know if anyone knows camaros on this site but it is worth a shot. starter is new as well as the alternator. When you get into the car and put the key in the ignition nothing happens at all. so some help would be appreciated
    Waterloo ont.
    Avg. Time Online: 18 Secs
    can be 2 things motor to body ground can do this but more likely + power feed to electrical system there ar fuseable links near the starter that tend to break down and near them is a common place for the wires to break. this can be tested by jumping power from + side of batt to the large wire on the back of the alternator. if car powers up then look at all connections near the starter closely.
    But be careful.. I don't think you can actually start it with the cables on the alternator terminal. I'm fairly certain there's a fusible link for about 80-100A, which will blow if you try to use the starter.
    Waterloo ont.
    ya this will only supply the car do not try to start it just diognos it
    Dec 2008
    Got her started, thanks for the help guys
    Ajax, ON
    Time Online: 4 Days 11 Hrs 26 Secs
    Avg. Time Online: 22 Secs
    'When you get into the car and put the key in the ignition nothing happens at all'
    make suer the car is in PARK if it is try 'Neutral'; could be the 'neutral safty switch'
    Time Online: 1 Day 12 Hrs 5 Mins 14 Secs
    What was the fix?
    http://webstyles.ca/JeepKings/Indepe...d-Sig-Line.jpg
    2004 Nissan Frontier SE 4x4 Crew Cab
    3.3L V6
    32" BFG M/T
    Cobra 29 NW ST
    Dec 2006
    Hamilton(Waterdown)
    dad has same car his ignition switch went and wouldnt start a while ago
    Dec 2008
    it was a combination of things. stripped bolts to the battery, loose wires, and the ignition. its up and running now
