Thread: JK Rubicon D-44 Evolution
    On a rock
    Time Online: 2 Days 21 Hrs 13 Mins 17 Secs
    Avg. Time Online: 14 Secs
    My Dad has a 07 JK Unlimited Sahara. It has a lot of mods already, one of them was the addition of the rubicon D-44 front axle. It already has 5:13 gears, lower control arm skids, steering stablizer relocator, track bar relocator,solid diff cover and more. He went thru the pain in the ass "death wobble" and with some research learned about the weak points of the JK D-44.
    So we added axle tube inserts with zerk fittings and o-rings to stop the tubes from bending and keep the mud out. Next we added C -Nuckle gussets, aparently they are easily bent. Finally we added a track bar relocator that not only relocates the track bar but is very strong and gussets the weak upper control arm bracket, I didn't take a picture of this bracket to close but it is one piece and wraps under the axle aswell.
    Attached Thumbnails Attached Thumbnails DSC03353.jpg   DSC03354.jpg   DSC03352.jpg   DSC03355.jpg   DSC03357.jpg
    On a rock
    A couple of more pics.
    Attached Thumbnails Attached Thumbnails DSC03365.jpg   DSC03370.jpg   DSC03369.jpg   DSC03371.jpg   DSC03372.jpg
    chippawa
    Time Online: 2 Wks 1 Day 23 Hrs 54 Mins 34 Secs
    Avg. Time Online: 1 Min 18 Secs
    total jealous of your welds..and shop for that matter lol
    what kind of welder were you using G
    1991 TOW RIG/DD toyota hilux surf ssr-x turbo diesel JDM SPEC
    1982 suzuki sj410 . stock ... no options rides like a slow bag of dicks
    Mississauga
    Time Online: 7 Hrs 8 Mins 53 Secs
    Nice deal but.... That weak upper control arm bracket is not worth gussetting as the bushing will pop out under heavy load ie. lots of flex. Once it does it will never press back in even with a new bushing. Trust me it took lots of swearing and not mention JB weld before I decided on a Currie unit that eliminates that shit with a JJ and a solid weldable piece.
    03 TJ Rubi, 4" Super lift coils w/ RE adj. Superflex arms, Pro Comp front adj. track bar, RE rear adj. track bar, 1" BL, 1" MORE bomb proof motor mount lift, Poly tranny mount, AR Baja wheels, 35" BFG Krawlers, Staun internal bead locks, Tom Woods CV drive shaft, Warn M8000, locker safety over ride, Four Real steal front stinger, Bestop tire carrier, Smittybuilt rear bumper, 4 Hella 500 on a light bar. The last ones for the yee haw factor
    Windsor, ON
    Looks great, now maybe he'll stop breaking trackbars.
    On a rock
    Finished it off. I like it, should have no more problems.
    Now were is the weak link?
    Attached Thumbnails Attached Thumbnails DSC03498.jpg   DSC03502.jpg   DSC03504.jpg   DSC03506.jpg   DSC03513.jpg
    On a rock
    I hade a little spare time so we nocked off the rear shocks and located them about 2" higher. It took about a half hour to cut and relocate. I see this mod only helping in the mud, or when he is backing up? Hey, every little bit helps right?
    Attached Thumbnails Attached Thumbnails DSC03523.jpg   DSC03525.jpg   DSC03528.jpg   DSC03531.jpg   DSC03533.jpg
