Results 1 to 3 of 3
Thread: 350 swap
    Jun 2003
    SIMCOE ONT.
    Time Online: 1 Wk 2 Days 11 Hrs 13 Secs
    Avg. Time Online: 46 Secs
    350 swap
    Looking at swaping a 1988 chev 350 4x4 into my C/J
    Will it work on the C/J rear ends using motor, trannie and transfer case
    will i have a problem with rear ends not accepting chev power train
    and is there any other problems I might encounter
    Oyte
    windsor, on.
    Time Online: 1 Wk 5 Days 13 Hrs 56 Mins 58 Secs
    Avg. Time Online: 1 Min 1 Sec
    Different size U-joints, weak rear end...wrong length of driveshaft just to name a couple of issues... BUT you can get a combination U-joint to take care of the differences between d-shaft and yoke of your rear diff....and cooling issues, your rad is backwards compard to the chevy unless you make the chev one work (mine fit in my YJ but had to fab it in), exhaust- the chevy stock exhaust manifold won't fit between your frame rails so you'll need some "hugger" headers or something (it fits fine between the YJ frame rails)... All kinds of other lil shit that you'll have to work around but really nothing to crazy if you can weld!!
    Jan 2003
    Paris
    Time Online: 1 Wk 3 Days 44 Mins 18 Secs
    Avg. Time Online: 49 Secs
    pm-ed you
    MegaTherion
    '87 YJ - Chev 355, 700-r4, Dana 300, Dana 44s, 4:10s, 4" Super Lift, 35s.
