Results 1 to 16 of 16
Thread: Brown, dirty looking engine coolant?
    Jun 2009
    Sudbury, Ontario
    Time Online: 2 Hrs 45 Mins 24 Secs
    I recently noticed the engine coolant in my 2000 Grand Cherokee is brown and
    dirty looking. Using a hydrometer, the fluid tested fine for temperatures, and
    the engine doesn't overheat. I was thinking maybe just a rad flush would do the
    trick. I haven't had one done yet. I was reading that sometimes more than one
    flush may be required to clean it out fully. Any advice on possible causes that
    would turn the fluid brown?
    Dec 2003
    Peterborough, ON
    Time Online: 2 Mths 2 Wks 1 Day 11 Hrs 30 Mins 9 Secs
    Avg. Time Online: 6 Mins 11 Secs
    I'd perform a leakdown test to ensure it isn't oil leaking into the coolant.
    Are you losing any oil/coolant?
    Jun 2009
    Sudbury, Ontario
    The coolant levels haven't changed, and I check the oil regularly and things are good. I had read that dirty coolant could be a sign that your engine is rusting internally, which I hope it isn't, or that the rad is rusting inside.
    Fine
    Time Online: 5 Mths 1 Wk 4 Days 14 Hrs 6 Mins 22 Secs
    Avg. Time Online: 13 Mins 15 Secs
    maybe your engine uses that orange coolant
    like mine does so it looks dirty????
    Leamington
    Time Online: 1 Wk 4 Days 10 Hrs 37 Mins 38 Secs
    Avg. Time Online: 56 Secs
    Just because your coolent is fine for temp doesent mea that its ok
    Coolent has additives for anti corosion and other things Personnally I would get one of those cheap walmart flush kits that slpice in line with the heater and flush your rad out 2 or three times to get any acids or sediments that have built up in your system
    then filler with a high quality coolent mixed to the proper ratio with water a new thermostat and rad cap wouldent hurt either *** I would do this as basic maintenance every couple years***
    Jun 2009
    Sudbury, Ontario
    Thanks for the tips, I'll look into one of those flush kits you mentioned.
    Elmvale, ON
    and dont forget, distilled water is the way to go when you mix a batch
    Keepn' the Rubber Side down.
    I Support OF4WD
    thank you i needed a new sig
    excelent advice antyfreeze can also becove verry acidic and can disolve aluminum there is ph tests you can do but its just best to change it every 2 years
    I have personally seen coolant eat through an aluminum block, 10 year old Corolla. Those flush kits from WalMart or CTC that go into the heater hose are still the best way (@ home) to flush a cooling system.
    Drain your existing coolant into a jug for recovery & recycling
    Add the Tee fitting to your heater hose (doesn't matter which)
    Attach garden hose to Tee, and remove rad cap
    Start the hose
    Start your engine
    Watch the junk come out your rad / overflow.
    Turn off hose, drain tap water, and refill 60/40 with virgin coolant and distilled water.
    Jun 2009
    kitchener,ontario
    Time Online: 13 Hrs 32 Mins 49 Secs
    yea i agree with the flush kits its a good start, have you been running hard water as your mixture with coolant because that would lead to this issue.
    Jun 2009
    kitchener,ontario
    the only thing is i believe that the 2000 grand cherokee has that 100,000 mile collant in it doesnt it? i remember reading that in the haynes when i was working on my buddies 2002 a couple weeks ago
    Jun 2009
    Sudbury, Ontario
    I'm not sure if the coolant has been mixed with hard water before or not. I just bought the jeep back at the end of April. It has high km's, in the 213,000 mark. I opened the coolant reservoir and smelt the fluid and it has a burnt smell to it, and just doesn't seem right. I'm not sure if the coolant has ever been changed or not in the past. The flush sounds like a good idea.
    Mississauga
    Time Online: 7 Hrs 8 Mins 53 Secs
    Sounds like that stop leak stuff is in the coolant. It tends to have a burnt smell to it. While flushing the coolant you may discover a leak in your system.
    03 TJ Rubi, 4" Super lift coils w/ RE adj. Superflex arms, Pro Comp front adj. track bar, RE rear adj. track bar, 1" BL, 1" MORE bomb proof motor mount lift, Poly tranny mount, AR Baja wheels, 35" BFG Krawlers, Staun internal bead locks, Tom Woods CV drive shaft, Warn M8000, locker safety over ride, Four Real steal front stinger, Bestop tire carrier, Smittybuilt rear bumper, 4 Hella 500 on a light bar. The last ones for the yee haw factor
    oshawa
    ya definatly flush it and urs will be the orange stuff those flush kits work awsome and wen ur done drain the block as well theres a bolt on the block to drain it to cet the majority of the coolant out i believe its on the drivers side below the head
    Jun 2009
    kitchener,ontario
    theres a product out there that helps seal it thats not that crap stop leak but it seals up the coolant passages with a coating thats good for high mile vehicals with coroded insides
    barrie,on
    Time Online: 1 Day 15 Hrs 5 Mins 42 Secs
    Avg. Time Online: 8 Secs
    if you mix the green coolant and the long life red stuff it goes brown as well maybe someone did that?
