Results 1 to 20 of 26
Thread: Staang's XJ Build
    Staang's XJ Build
    Well I have a few different threads started about my build. I started them before this section was here.
    I now have a new addition to make so I'm gunna put a bunch of links in for my other mods I have done.
    Front longarms
    http://www.jeepkings.ca/forums/showthread.php?t=71463
    Rear 4 link
    http://www.jeepkings.ca/forums/showthread.php?t=76641
    Custom axle build, front 44-9 & rear 9" - bigger tires too
    http://www.jeepkings.ca/forums/showthread.php?t=88416
    I have also done some steering mods which I have no threads for...
    Beefed up the area of my frame where the steering box bolts onto, removing the silly aluminum spacer to fit some DOM tube in its place.
    Crossover steering with 3/4 heim joints.
    Last year I rebuilt my 2.5L and converted from throttle body injection to multi port injection. Yes, I like my 2.5. Not enough power to break stuff!!
    Now onto the latest... Since my 2.5 does not make lots of power I end up slipping the clutch when doing tough climbs. To solve this problem I am installing a 231/d300 doubler.
    http://www.youtube.com/staang
    Is this the doubler you were talking about at roadkill? PLease let me in one were you got the shaft made again?
    Nope I ended up buying this complete for a decent price.
    I was gunna work with Tim (TMR Customs) to make a shaft. Most likely still will.
    while your at it get tim to make you an adaptor to bolt a ax15 or nv3550 in place of the ax5 that will realy make your combo bombproof
    http://advanceadapters.com/product/2216/712564.html
    I have had no troubles with my AX5, and the lil 2.5 wont make enough power to break the AX5.
    Quote Originally Posted by Staang View Post
    True.
    But the 5.0 Mustang engine you're dreaming of slamming in there certainly will.
    rockwood
    Time Online: 3 Wks 6 Hrs 1 Min 57 Secs
    Avg. Time Online: 1 Min 44 Secs
    where did you get the adapter for the doubler and how much$$ looks good
    Quote Originally Posted by JPhoenix View Post
    True.
    5.0L is no dream I have been collecting parts for a while now.. I have everything needed.. Just need to freshin it up. I also would like to get some use out of my freshly rebuilt 2.5
    Quote Originally Posted by giezy View Post
    I bought the entire unit already together. The adapter goes for $500US. Get it from D.D. Machine.
    The doubler will make your like alot nicer on the trail!! I will not give mine up for anything now! I have a DD Machine set up and it works flawlessly.
    yes I'm very excited about it!! Just need to clear some time to put it in.
    Time Online: 7 Hrs 24 Mins 27 Secs
    No worries. I have all the faith you will MAKE time!
    www.staangsFAB.com
    NAPA Parts Professional.
    Staang's photographer, videographer & other half!!!
    Pirate for life.
    So i'm waiting on a sweet cable shifter set-up to arrive in the mail from North West fab out of BC.. It is real nice!! I cant wait to see it in person. I'll post some pics when they arrive.
    Ya that make some sick twins stick parts. Mimicked mine off their a bit.
    So I have the doubler mocked into place. I needed to check the clocking on the D300 and to mark where the floor needed to be removed.
    I am also going to be making a mount to carry the weight of the 300.
    The mechanical shifters come through the factory hole for the t-case lever, this was nice. The shifter for the 231 is on the oposite side of the trans tunnel. A hole was needed for this. I may even be able to use the factory center console.
    Here are some pics of the progress.
    oshawa
    looking good buddy
    Feb 2006
    caledonia
    Avg. Time Online: 5 Mins 40 Secs
    Can't wait to see it today brotha!
    Well I've got everything in and workin.. Went testing this weekend at Greens..
    WOW.. This is the best mod I have done to my jeep.
    I REALLY like the doubler it worked flawlessly this weekend!
    Bastard
    My doubler is going to be in my Jeep for a long time to come! One of the best mods I have done to make mine work better on the trails.
    Jan 2006
    Belleville, Ont
    Avg. Time Online: 3 Mins 43 Secs
    Wonder how well it would work with a Automatic...I don't know if the brakes would be able to stop me in double low..lol
    99 Ram Toy Hauler Edition
    OF4WD Member 5275 www.4-lo.ca
