Thread: winch help
    winch help
    Hi i'm new here and i'm not sure if this is the place to post this but i'll try anyways I'd like to place an 8000lb milemarker winch on my 09 ranger but i keep getting cross stories on what i'd need to power this sucker. The two stories i'm getting are this first that i'll need to upgrade to a 150 amp alternator and run a dual optima gel battery setup. the second story is that my stock 90 amp alternator will be find a grab a high quality interstate battery with the highest cold cranking amps i can find. what do you guys think would be the better setup.
    Aurora
    Mellow
    Time Online: 1 Mth 1 Day 7 Hrs 49 Mins 29 Secs
    Avg. Time Online: 2 Mins 35 Secs
    some will say just use what you have until it breaks...
    I just use my stock alt with a yellow top optima...
    I have a warn 8274(8000LBS) winch
    selkirk ont
    Time Online: 1 Yr 3 Mths 2 Wks 4 Days 7 Hrs 26 Mins 2 Secs
    Avg. Time Online: 39 Mins 2 Secs
    ^i agree. i'm running a yellow top optima and 8500 lb superwinch with no issues other than loose connections. i do plan on a dual battery set up for this winter.
    WHAT WOULD MACGYVER DO?
    I heard from someone to run two of the optima yellow top gel batteries if that makes any sense and then another guy told me gel batteries are crapa nd to just go for one of the really good interstate quality batteries.
    Aurora
    Mellow
    1 yellow top will do the trick.... or another deep cycle battery.... you dont have to use two.
    Apr 2004
    Owen Sound
    Time Online: 16 Hrs 37 Mins 30 Secs
    I run my factory bat, and alt etc and havnt had a problem yet
    If your shaft ain't wet... your not in deep enough
    2003 Rubi, 3.5" RE kit, CB, Titan 10K winch, offroadsupply.ca bumper, sliders and rock rings.
    www.ctmotorsports.ca
    www.rockspyder4x4.com
    I was just at walmart and one of there workers recommended an optima blue top marine battery cause it has 1000 wat and it comes with posts that will fit a car could there be any harm in running one of these.
    Time Online: 1 Day 1 Hr 11 Mins 14 Secs
    I run two red top optima's with a 12000 titan and under heavy load she sucks the juice out of them now this is hard pull where she is almost stalling winch i say more power the better like anything else u can never have enough.
    www.youtube.com/user/Badger5656
    www.cardomain.com/ride/3069834/Badger5656
    95 ZJ 5.2L
    Performance ecm, Full Flow Master super 40, 8" Clayton Front Longarm, HD Clayton Pitman Arm, HD Clayton Track Bar, eagle aloys 15x8's, 34x12.50R15LT trxus mt , Front bumper Titan 12000 Winch, Rear Bumper, 8.8 Rear Axle
    Tottenham
    Avg. Time Online: 5 Mins 14 Secs
    Quote Originally Posted by EatingSpam View Post
    in this case that's what I would say... when your stock battery dies upgrade it to a yellow top or another brand of deep cycle... you should get a couple years or more out of the stock battery.
    S.S.O.
    OF4WD
    Aurora
    Mellow
    O forgot to mention.... my new yellow top still(with a big pull) can drain down. I ususally rev a lil while using the winch.
