Thread: 4 inch suspension lift and 2 inch body lift
    nanticoke
    Time Online: 1 Hr 34 Mins 57 Secs
    87 yj, do i need longer driveshafts if I go with a 4in suspension and 2 inch body lift??
    is there any thing else
    I have the 4 inch rough country lift
    Nope. You'll need to install the transfer case drop that should be included, and you'll likely have to trim around the shifter hole if you're driving a standard, to get enough room to shift to 1,3 and 5th gears. I did with my '88.
    nanticoke
    ok, thanx,
    it is auto
    Much less work then. You may still need to trim where the transfer case selector lever comes through.
    Waterloo / Ottawa
    Time Online: 22 Hrs 24 Mins 38 Secs
    How much trimming did you have to do?
    I did not trim but it wants to pop out of 2nd all the time, I hold it there until I hit 3rd and up
    Rod
    ___________
    -94 Camry - blown tie rod retired
    -89 Black YJ 4.2L, 92 axles with 4.10 gears, shogun racing seats, 33x10.5 BFG MT, 4" Rough Country Lift, bed lined tub
    -98 4Runner 210K on it now
    Fine
    Time Online: 5 Mths 1 Wk 4 Days 14 Hrs 1 Min 39 Secs
    Avg. Time Online: 13 Mins 17 Secs
    Quote Originally Posted by NewToYJ View Post
    instead of trimming i bent the shifter, works great
    its the 4x4 shifter 4low that wants to pop out once
    and a while now, looks like have to trim this one.
    Time Online: 14 Hrs 5 Mins 36 Secs
    thats the set up I am running, 4" is as big as you can go on stock driveshafts.
    with the body lift you will need to extend all of your shift links and entend your steering shaft, other then that there are some vaccume line extentions and relocation brackets included if nessisary.
    I got mine from just jeeps for $250, took about a week to get it done, with dealing with the rotted body mounts and rusted to f*** bolts.
    KLUTCH
    91YJ 4"RC 2"B 33"Goodyears Plated HM Bumpers K&N Flowmaster CB
