Thread: front digs?
    north york.
    front digs?
    i've seen it done and am wondering what i need to do it.
    do i have to modify my dana 300 in any way to do this.
    also i've been around, so i've seen the cutting brake handles in buggies but dont rally know much more that that, except thats how you put the brakes on the axle thats unhooked so to speak.
    any tips or help id appricate. im going to get'er done anyway but its much eaiser to learn from expereinced guys that braking stuff a couple of times first.
    this is what im working with
    dana 300 on the back of a crawl box.
    thanks for the help
    Ajax Ont
    Avg. Time Online: 1 Min 59 Secs
    I think what you are looking to do is Twin stick your D300.
    there is kits for about 150ish
    or you can do this yourself...for about 40ish.. just make sure you upgrade the spring
    as i herd it sometimes lets go when steep declines
    this site will tell you what you need to do
    http://www.jeepgod.net/twind300.html
    Hopefully I,ll get around to doing mine this winter...
    north york.
    sorry the dana 300 that i got has already got twin sticks.
    but i thought you have to do something to the inside to make it independent?
    Beamsville
    Time Online: 3 Mths 4 Days 17 Hrs 14 Mins 43 Secs
    With your 300 can you put the rear in neutral? if so then for a front dig you would put the rear in neutral and use the cuttign brake to lock the rear from rolling. Then power to front wheels only and you will pivot arround the rear wheels
    Professional lunatic
    Mar 2003
    London, on. ca
    Time Online: 2 Days 44 Mins 56 Secs
    Avg. Time Online: 10 Secs
    put this http://www.cncbrakes.com/cb.asp?grp=...52S&subseries= in a little cj on 42's. Works good but i think the 496 C.I. big block really helps it kick around the tight corners.
    You need a bit of force to keep the wheel locked but it's effective.
    I wish my grass was Emo, then it would cut itself.
    I can't do split brake cutting due to the spool.
    But I use a 4000psi manual ballvalve for a "Line Lock" to hold my rear still. P-Brake cables just couldn't hold against the low gearing.
    You may want to look into AA D300 Outputs. The stock D300's are none to let go under stress.
    Time Online: 4 Hrs 55 Mins 14 Secs
    i run a CNC 3/4" brake on the rear, but seen driveline ebrakes work good.
