Results 1 to 12 of 12
Thread: New HEI for CJ7 won't run
    Paris, ON
    Time Online: 1 Day 1 Hr 59 Mins
    Hey, just intalled a new HEI distributor on my 83 CJ7. It stars but will only run with the key in the start position. There is power to the distributor with the key in the run position. I can't figure it out. Enyone have eny ideas, or run into this before? Thanks and CHEERS to your help!!!
    Apr 2006
    Dresden Ontario
    Time Online: 3 Wks 19 Hrs 7 Mins 22 Secs
    Avg. Time Online: 1 Min 47 Secs
    Check your voltage in the run position should be like 13.7 volts or so. Some circuits are limited to 5 volts and won't be enough to run the HEI
    Don't let fear and common sense get in your way.
    1985 CJ7 Aluminum tub, 31's
    1985 CJ7 Fiberglass, lift, 33's, 5.3 Vortec, NV3550
    1985 CJ7 All steel
    Doing my part to keep these old CJs alive
    St Thomas Ontario
    Time Online: 1 Mth 3 Days 8 Hrs 7 Mins 46 Secs
    Avg. Time Online: 2 Mins 44 Secs
    Yup, what he said. If you tapped in to the wire that was running your ignition before it's going through a resistor and you won't be getting enough voltage. It runs in the start position because you're supplying full circuit voltage through the resistor by-pass from the solenoid. Best is to run a new heavy gauge wire from the ignition switch that has full voltage in the start and run position.
    Commando, Jeepster, Jeepster, AMC Eagle, Commando, Jeepster, another Commando, AMC Eagle, another Jeepster.
    Paris, ON
    I thought of that so I jumped a wire to the distributor and it still don't run.
    Apr 2006
    Dresden Ontario
    Ok might be a dumb question but do you have the start wire and run wire attached to the same terminal of the HEI. They should be! The other terminal is the tach terminal.
    Paris, ON
    Yep Yep and there's 12.4v
    Apr 2006
    Dresden Ontario
    Well that doesn't make sense:confused: Have you tried removing all wires and then running a single wire direct from the battery to the HEI. Keep in mind you will have to disconnect the wire to get it to stop by doing this. If that works then you'll know its in the wires somewhere.
    Paris, ON
    Well don't know what I did wrong but when I pulled off the wire for the tach it runs great. So know I have to find what I 've done wrong thanks for eveyones help!!
    Apr 2006
    Dresden Ontario
    The tach may be faulted to ground?
    Paris, ON
    Hey thanks for your help I'll have to checker out tomorrow wifes out and I get the kids. Thanks again CHEERS
    Apr 2006
    Dresden Ontario
    Your welcome. Always glad to help out a fellow CJ owner. Good luck
    Paris, ON
    It was the tach, new problem now. check out only runnin on 5
