Thread: Radiator Support Snatch Point
    Time Online: 18 Hrs 51 Mins 39 Secs
    So I was going to order one from Kevins Offroad but I decided hey i'll just make one, cost me about $100 in materials including the shackles. Much cheaper than the $200 or so I would've spent and I think it looks pretty damn good if I do say so myself. I also didnt have time to wait the 10 days for delivery as I am hitting some trails tommorow.
    Check out Kevins here...
    http://www.kevinsoffroad.com/zj/zj_rad_support.html
    What I did:
    I took out the factory radiator support and replaced it with 1/4" brackets and put square tube between it for the actual radiator support. I then milled the holes into the brackets for the factory bolt locations and the holes for the shackles. I also took another piece of 1/4" and slid it into the unibody with the same holes milled in it for added strength in the front part of the unibody.
    I used grade 9 bolts and the shackles are 3/4" pin rated for 9500 pounds each.
    Front views.
    Side views.
    97 ZJ - Daily Driver
    93 ZJ - Parts Truck -- PM Me if you need any parts.
    good job dude
    mabey want to weld a thick washer around both sides of the hole for the shackle just for fun
    next time take some build pics
    (i know its tough when your busy building)
    I am planning on adding a little piece of round bar on either side to take up the slack of the shackles, but they don't move around at all really while driving. I just wanted to get it done and on the truck as I had to go pick up my girlfriend. I would've taken pics but I forgot my camera at home and didn't go get it until after I was done and had started moving my vents for the diff and stuff. (Check my other thread for that one)
    North Bay
    Time Online: 6 Days 3 Mins 36 Secs
    Avg. Time Online: 29 Secs
    Looks good.
    96 ZJ, Under the knife, 6.5", Custom Longarms, 4.88, One Tons, 40" MTR's
    97 ZJ Limited V8, DD
    97 XJ Sport, 4.5" RE & Some Stuff...New Addition to the collection, What to do with it???
    Ahh, the women can wait!!
    Kidding.
    I was going to say the same. Reinforce the shackle mounts. ANY pulling from a slight side angle will bend those up like nothing.
