Page 1 of 4 1234 LastLast
Results 1 to 20 of 69
Thread: Move your vents up!
    Time Online: 18 Hrs 51 Mins 39 Secs
    Move your vents up!
    Want to keep the water out of your diff's and transmission on those deeper water crossings? Your going to have to move your vents up as high as they can go. Thats what I did today. The factory location for the front diff is actually pretty good I just moved it up a little bit higher, It used to mount to the side of the air box. The rear one however just went up into the unibody and would've easily sucked up water on a crossing. I routed this one up to the front in the same location as the front diff vent.
    The factory hose is 3/16" so I went out and bought a role of that from Napa.
    Factory Hose
    Where the vents ended up. The front one originally was mounted to the side of the air box.
    Find your vent on the diff.
    It originally went from the vent into the unibody almost right above itself
    New hose on the vent
    I then started routing it down the unibody with the brake/fuel lines. You can see I left quite a bit of excess here, this is because over the winter the jeep is going up about 8" and I didn't want to have to do this again. If you do this make sure its tucked up and out of the way of anything that could grab it and rip it off.
    I secured it along the brake/fuel lines with zip ties
    I tried to keep it as far away from the exhaust as I could at this point as I didn't want the radiating heat to melt it.
    I ran it under the motor mount in the little nook that hides there.
    97 ZJ - Daily Driver
    93 ZJ - Parts Truck -- PM Me if you need any parts.
    North Bay
    Time Online: 6 Days 3 Mins 36 Secs
    Avg. Time Online: 29 Secs
    Thats a long vent line!!
    I removed my abs on my jeep and the rear axle line now goes up through where the abs wires used to go into the cabin, right under the rear seat.
    I moved my front line back to the firewall.
    96 ZJ, Under the knife, 6.5", Custom Longarms, 4.88, One Tons, 40" MTR's
    97 ZJ Limited V8, DD
    97 XJ Sport, 4.5" RE & Some Stuff...New Addition to the collection, What to do with it???
    Time Online: 5 Days 10 Hrs 11 Mins 25 Secs
    Avg. Time Online: 26 Secs
    they have sealed bellows which cost about $5 and no lines to run anywhere
    Time Online: 10 Mths 3 Wks 5 Days 36 Mins 37 Secs
    ^ I was just going to suggest that.
    Save yourself a lot of aggravation and just attach vent bellows on your axles and t-case vents. There is no need to run vent lines all over your truck.
    heavy duty balloon works as well.
    Oct 2009
    bewdley
    Angry
    Time Online: 5 Days 16 Hrs 28 Mins 57 Secs
    Avg. Time Online: 28 Secs
    would napa carry those bellows?
    I like it.
    Nice work!
    Guelph, Ontario, Canada
    Time Online: 1 Wk 2 Days 15 Hrs 50 Mins 3 Secs
    Avg. Time Online: 47 Secs
    Has anyone here tried this? I would like to try it but would like to here of some peoples experience first.
    '87 4Runner, slightly llifted and lots of fun!!!
    Oct 2002
    Pefferlaw, Ont
    Time Online: 6 Days 15 Hrs 10 Mins 27 Secs
    Avg. Time Online: 32 Secs
    I use them on both my axles, T case and for the hydro reservoir, no issues, works well, less tubes running round the heap (less to get caught on something).
    89 YJ, 4.0 HO, 999 Auto, Twin Sticked D300, SOA, Full width 5:38 D60 front ARB, 5:38 full float D60 rear Detriot, 35 spline shafts, disc brakes all round, aluminum rockers, cage mounted racing seats, custom dash, tilt /quick disconnect steering, 39.5 TSLs on hummer wheels with double bead locks, full hydro steering, hydro boost brakes, 8274 w/synthetic rope, CJ front clip & tail gate, Custom Olive Green Paint Job !
    I will look into these I didnt like having the line so long anyways.
    Quote Originally Posted by zombie View Post
    Yes, I have been running them for 2 years with zero issues. It saves a heap of plumbing, are easy to install and creates a positive seal.
    Quote Originally Posted by purdyYJ View Post
    Nope. PSC or ATV shop are the only suppliers I have heard of.
    Sep 2009
    Time Online: 2 Mths 3 Wks 1 Day 6 Hrs 9 Mins 6 Secs
    Avg. Time Online: 6 Mins 47 Secs
    Same question as purdyYJ who carry's these? partsource? napa?
    Beamsville
    So then who carries these?
    I have them on my dif's they have been OK for the few miles I have run
    Professional lunatic
    Holy smokes people....pay attention!
    1) PSC carries them.....thank igotafrigginjeep for linking for the lazy.
    2) Dvsjeep is a PSC dealer and he was stocking these at one time....PM him.
    3) Some ATV shops carry them as they are a popular addition to ATV's.
    Sep 2009
    Sorry was eating sandwich . . . didn't hit refresh before posting
    bought mine from Royal distributing in innisfil
    yeah, soo umm who carries these? All i know about them is that i forgot to put one on the rear end when we got up north... now...Milkshake!!!
    Oct 2005
    Vankoughnet
    Time Online: 9 Mths 1 Wk 1 Day 10 Hrs 18 Mins 15 Secs
    Avg. Time Online: 22 Mins 57 Secs
    I have a few left in stock, shoot me a PM if interested. Burlington
    Quote Originally Posted by Chevy YJ View Post
    Yer fail detector is broken, isn't it? lol
