Results 1 to 8 of 8
Thread: 93' Eagle Talon TSi
    Petawawa
    Time Online: 4 Days 14 Hrs 36 Mins 8 Secs
    Avg. Time Online: 22 Secs
    93' Eagle Talon TSi
    Attached are some links to threads I have started in attempts to get my turbo swapped Laser on the road.
    http://www.dsmtalk.com/forums/showthread.php?t=215849
    http://www.dsmtalk.com/forums/showthread.php?t=207527
    http://www.dsmtalk.com/forums/showthread.php?t=198616
    http://www.dsmtalk.com/forums/showthread.php?t=198651
    I bought an ECU, which I thought was the big problem, now my car will start(and struggles most times.), but won't keep idle, I have messed around with the BISS, and wires 6 and 14. Nothing.
    I think its something to do with the throttle body. Out of the car, opperating the TB by hand, the motor almost reacts opposite to what I do. When I close the throttle, it wants to run, and when I open it, it wants to die.
    Oh, and we put new gas in it.
    Can anyone tell me whats up?
    It runs on all four.
    The fuel pump has been ruled out, since we have had it running for about 45 seconds, manually working the throttle.
    Would the knock sensor keep it from idleing/staring correctly? Because mine is not plugged in.
    -Ian
    This is not my daily driver, but if I can get it running, it will fund my TJ.
    Thank you.
    '02 TJ Sport
    2'' Rubicon Express Eco-Lift / 33'' ProComps / Superchips FlashPaq / ARB Safari Snorkel
    North Bay
    Time Online: 2 Days 20 Hrs 51 Mins 5 Secs
    Avg. Time Online: 14 Secs
    Its kind of hard to diagnos a problem without seeing whats going on under your hood.
    the knock sensor doesnt do anything to the way it runs.
    do you have the correct maf? all your ic piping connected tight?
    Guelph
    try the MAP sensor
    just unplug it and if it runs thats your problem
    North Bay
    he doesnt have a map sensor
    milton
    Avg. Time Online: 39 Secs
    i would definately say mass air flow. i might have one in my garage if you want me to take a look. i know i have coil packs lol.
    '99 superduty, 7.3L diesel. 4x4, ex cab short box. edge evolution programmer. straight pipe, torque converter lock up switch. single 7" stack, built tranny with some billet bits inside, 7' trac bars, pyro,boost an tranny guages. 4" lift in the front 5" rear. 305 70 16 mickey thompson baja mtz's on m/t classic 2's. now with dana 60 front, 10.5" rear 3:7.3's. 5" airlift bags in the rear.
    2002 polaris pro-x 440 with 2004 600 motor. walker evans remotes all the way around.
    milton
    just realized your location. lemme know if you want me to look. but i do believe it would be the mass air flow.
    Petawawa
    Ahha!
    I had an Aeromotive AFPR on there, tuned to the incorrect fuel pressure. Still, it won't idle right, however it ran goofy for about 2 minutes.
    They call this progress.
    On the dash, I have a light, looks like a filter. I'm guessing thats why a lot of you guys said MAF.
    I'll unplug it, and try it next time I'm around the car.
    Thank you to all.
    North Bay
    The car wont run right with the maf unplugged. do you have any leakes between your maf and turbo intake?
    any small leak in the intake tract will cause the car to run like ass.
