Results 1 to 20 of 39
Thread: andys jeep (yes i have a jeep)
    ok so over the last year i have been putting parts away to rebuild a jeep to my liking.
    i need some help with the direction im going to go and what final parts im going to need to get it to work opinions please.
    here is the parts list
    -77 bronco hp d44
    -bronco 9in rear
    -6 in xj rear leafs
    -69 351 windsor (needs rebuild)
    -88 302(5.0) mustang engine ready to rumble
    -th350 trans
    -np231j with 6pin planitary from 231hd
    -ford 31 spline input np 205
    is it worth getting a spud shaft and adapting the th350 to the np205?
    should i source out a zf5 speed (i hear it bolts up to the 205 with mods)
    would the zf handle the well built windsors? 300hp 330tq?
    im open to all possible combos but i realy have my heart set on the windsor small blocks
    its all gong to find its home in a stout yj frame with a gen right diy roll cage
    i also hope to run 37 bogger tsl combo on the lightly modded axles.
    and a before shot of the worn down jeep
    Time Online: 1 Mth 4 Days 1 Hr 21 Mins 48 Secs
    Avg. Time Online: 2 Mins 47 Secs
    What about using a Ford C 6 trans. Would that not bolt right up to the 351 and 205?
    02 TJ, 4" lift,35'' MT Claws,D44,K&N FIPK,Bestop supertop,Magnaflow cat back,Smittybilt rear bumper with swing out carrier, PSC stinger, 10 000lb winch. Tubular Metal Worx front flat fenders and flat rear flares.
    77 CJ7. Gone but not forgotten
    10 Grand Cherokee
    ZZZZZZZZZZZZZZZZZZZZ!!
    More pics!
    hamilton/norfolk
    Time Online: 4 Mths 1 Wk 4 Days 17 Hrs 32 Mins 32 Secs
    Avg. Time Online: 10 Mins 49 Secs
    you should snap a pic of the heap in it's current state. air in 3 out of 4 tires ain't bad all and all
    should be an interesting build to follow
    Quote Originally Posted by Mayheminc View Post
    Life is good in the republic of bacon
    RETREAD #9
    Dec 2006
    Hamilton(Waterdown)
    Start stripping and hacking and getting shit done and go form there!!
    I say go SOA, with F-150 leafs in the back, exploder leafs up front, that will give you room for up to 40" tires no problem, it will stretch yoru ass end like 5" or so to give you better drive shaft angle to!!!
    The put your axles under it, tires, roll cage, and by then your motor will be rebuilt, ready to toss in in a weekend and you can be wheeling!!! youll figure your motor combo out by the time the rest of the jeep is built and then you can put up pictures!
    Andy, if you need a c6 the one that the 205 was bolted too is still sitting down here.
    Jun 2007
    Lindsay. Ont. Canada
    Time Online: 3 Days 15 Hrs 2 Mins 41 Secs
    Avg. Time Online: 17 Secs
    I am going to stick my 2cents in as well. If you are going to use the turbo 350, you can buy an out put shaft and adpter for the turbo 350 to a Dana 300. Then again you could run a jeep 231 as a doubler to the Dana 300, flip it and have a lot of gear options. Just the 231 to D300 ratios gives you about 7to1 at the D300 out put youke. ( thats not including your trasn first gear ratio as weel).Why not run a 4speed auto with the doubler, etc. The options are endless, or as many as your cash will let you go. I wnet through as this as well. Jeep parts are easy to find. All the best with your choice. I vote doubler. Cheers. Rusty Iron
    Jun 2007
    Sorry for the spelling every one. Cheers.Rusty Iron
    pics
    here is some pics for the guys who dont read
    piles of parts
    the pile of jeep
    and the frame im going to refurbish
    i wont be ripping into the jeep untill the chassis is ready to roll (probaly around march)
    but the chassis work starts next week!!
    Attached Thumbnails Attached Thumbnails 001.jpg   002.jpg   003.jpg   004.jpg   005.jpg
    Whitby, Ont
    Time Online: 8 Mths 3 Days 23 Hrs 11 Mins 20 Secs
    seems like allot of work just to fix the internal slave cylinder
    bawahahahahahahahaha
    Anyways, get her built, lets see ya out next year! Just don't run over me!.
    ᄅ# pɐǝɹʇǝɹ
    Good luck with the build Andy. If there's anything I can do to help, Lemme know.
    updates
    and pics too
    she is inside and warm and getting started on the restoration/renfocement of the body
    tossing the tailgate for a cargo locker in the back going to keep the hard top but no rear window.
    im going to seal it off from the pasenger compartment with some pipe insulation and a windjammer.
    high hood and tube fenders all hand crafted of course
    rebuilt ax15
    mustang 8.8
    this thing is my winter driver and its time to get her road worthy
    the only progress to show is air in the tire and finaly pryed the tailgate open
    but its in the shop and that was a big step here is pics to prove it for the neh sayers.
    nice to get a few before shots too
    mississauga
    Time Online: 13 Hrs 33 Mins 27 Secs
    i see the kids camaro is still there LOL. You going to be around tomorrow, i need you to cut some holes for my rear shock mounts.
    Avg. Time Online: 28 Mins 55 Secs
    That's a pretty skinny tire in the back...going for the cut through the mud and get to the bottom approach?
    I should be able to drop by a few times this month during the week to give you some help...even if it's just sorting sockets!
    thanks i have lots of better jobs for you.
    removing the mud soaked interior that has been out in the rain all summer
    shoveling all the mud out
    windsheild frame,front end,roof,dash,transmision,axles all have to be removed
    Brampton/ parry sound
    Time Online: 3 Wks 4 Days 4 Hrs 31 Mins 56 Secs
    Avg. Time Online: 2 Mins 4 Secs
    Looking forward to seeing your build, keep the pics coming.
    that tire would make a killer coffee table lol
    By the lake
    Time Online: 1 Mth 3 Wks 5 Days 1 Hr 47 Mins 58 Secs
    Nice to see that yj gettin some love... If you need any help, let me know.
    hamilton
    Time Online: 1 Day 22 Hrs 55 Mins 46 Secs
    Avg. Time Online: 9 Secs
    that may be the cleanest looking jeep frame i have seen haha
    here is some progress an addition for deep water fording
